Hurst shifter
Old Jan 6, 2014 | 12:07 PM
SB64's Avatar
SB64
Default Hurst shifter
I have a 69 and have seen that you can use the Hurst unit with an after market shifter that looks stock. Does anyone out there have this setup and an opinion.?????
Old Jan 6, 2014 | 12:22 PM
4 speed's Avatar
4 speed
i had it on my 73, the rev. lock out is just a simulated. shifter handle had to be heated and bent to fit side to side. but all in all, never missed a shift afterwards
Old Jan 6, 2014 | 12:30 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
I had one on my 69 and it worked great, but like the previous poster said it seemed like the shift handle was located too far to the left. It hit the console in reverse. I was able to shim it to where it worked OK but I wasn't proud of that solution.
Old Jan 6, 2014 | 01:13 PM
qtlow's Avatar
qtlow
Get the one that Corvette Central sells. It has a greater offset and fits better.
I have one in my car and I'm very happy with it.
The other one that's available is slightly different with less offset and requires shimming according to the people that have used it.
Here's a link to a thread about this subject.
Old Jan 6, 2014 | 02:24 PM
SB64's Avatar
SB64
Default hurst
Okay so the reverse lockout is just for show.
Old Jan 6, 2014 | 09:52 PM
Lupigiato's Avatar
Lupigiato
Reverse lockout is just for show. Here's the setup in my 68.
Old Jan 6, 2014 | 10:22 PM
gbvette62's Avatar
gbvette62
It's spring loaded, so that you can lift it up, just like a stock shifter. The difference is, it doesn't do anything when you lift it......except maybe fool the car show judges.
Old Jan 7, 2014 | 07:58 PM
SB64's Avatar
SB64
Default hurst
Can you use the stock ball,since I have a 69 with the black chrome that I would like to use.
Old Jan 7, 2014 | 08:48 PM
gbvette62's Avatar
gbvette62
Yes. The one on Lupigiato's car is chrome, because it's a 68. 68's (and 64-67's) used chrome *****, while 69-81's used a black chrome ball. Other than the type of chrome, used on the ball, the diameter and thread is the same for all 64-81 Corvette manual shifter *****.
To Hurst shifter
