source for NOS brake pads?
Old Jan 6, 2014 | 02:07 PM
Spot Rot's Avatar
Spot Rot
Default source for NOS brake pads?
Back in the day, I installed many dozens of OEM / Delco pads and never had a problem with them.
The aftermarket pads I've tried are dirty, squeal or both.
The Hawk PC pads dirty the rims within 50 miles of driving, squeal, and have poor grip around town. In fact, I'll give them away to any forum member when I get good old fashion pads.
Old Jan 6, 2014 | 02:15 PM
Mike Ward's Avatar
Mike Ward
Any GM dealer has them...........
Old Jan 6, 2014 | 05:34 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Interesting. Does anyone know about the quality/pricing of said pads?
Old Jan 6, 2014 | 09:25 PM
Roughrider's Avatar
Roughrider
Were original pads asbestos? If so, they wouldn't be available new anymore unless you find someone with a stash sitting on a shelf somewhere.
Maybe oe was semi-metallic. Maybe someone will know the answer.
Old Jan 6, 2014 | 09:47 PM
Mike Ward's Avatar
Mike Ward
OE pads were organic. Still are.
Old Jan 6, 2014 | 10:32 PM
gbvette62's Avatar
gbvette62
The GM pads were and are organic.
The stock pads are what are known as D-8's. Delco offers them in two styles. With riveted pads, they are available as AC Delco part number 17D8, and as bonded pads they are part number 14D8. Both type are organic, Delco doesn't offer the D-8 with a semi-metallic lining.
The same pads are used on all four calipers.
Old Jan 7, 2014 | 10:17 AM
Spot Rot's Avatar
Spot Rot
Thanks for the Delco part no.s
I'd be surprised if Delco still uses the same friction material as they did almost 50 years ago but I'll look at them.
Also suprisingly, it appears that asbestos is not banned in brake or clutch friction material in the US yet. And asbestos was used in many pads/shoes classified as organic.
Old Jan 7, 2014 | 12:10 PM
Spot Rot's Avatar
Spot Rot
If the Amazon photo and description are accurate, the current 17D8 is not the same as original:
"Manufactured from ceramic and non-ferrous materials"
photo shows and no vertical expansion slot in the middle
Old Jan 7, 2014 | 12:34 PM
Mike Ward's Avatar
Mike Ward
Try GM part number 18028641
Old Jan 7, 2014 | 01:15 PM
Eljay's Avatar
Eljay
Asbestos is not man-made so I guess all asbestos pads are "organic"
Old Jan 8, 2014 | 09:23 AM
Spot Rot's Avatar
Spot Rot
From my little research, it appears that asbestos pads were classified as organic. And although asbestos may not be banned in the US for use in brake pads, it is likely that many manufacturers have switch to non-asbestos materials.
RE: GM part number 18028641
A current eBay add shows photos of a Delco box labeled with both GM part number 18028641 and 17D8. These pads are visibly different than OE in at least that the photo shows no vertical expansion slot in the middle. Also the pad material looks darker than I remember though that may be just a photo issue (or memory issue).
P.S. the ebay ad offers the new set for $27 with shipping if anyone is interested.
I'll check the booths at the NCRS FL meet in a couple weeks to see if any NOOS are available. I'm tired of wasting money on aftermarket pads, and it appears the current Delco and GM pads should fall in that questionable category.
P.S. just to make brake descriptions more clear (though more complicated), "Organic" appears to be commonly used for brake materials whose components are not man-made. "Organic" chemistry however refers to compounds and materials that contain carbon atoms.
To source for NOS brake pads?
