Exh Manifold Stud Question
Old Jan 13, 2014 | 08:17 PM
Cavu2u's Avatar
Cavu2u
Default Exh Manifold Stud Question
What brand are you guys using for header manifold studs? Going in aluminium heads.
Thanks in advance.
Steve
Old Jan 14, 2014 | 06:24 AM
Phil Zell's Avatar
Phil Zell
Thanks in advance.
Steve
I use allen head stainless and use plenty of anti-seiz
Old Jan 14, 2014 | 10:15 AM
jcuprisi's Avatar
jcuprisi
Please read your installation instructions carefully. I installed aluminum Edelbrock heads and it clearly states NOT to use anti-sieze on aluminum. It will give erroneous readings and you will overtorque the bolts and damage the threads. I also used Allen Head bolts for easier access.
Old Jan 14, 2014 | 03:46 PM
Cavu2u's Avatar
Cavu2u
Default Like These?
http://www.ebay.com/itm/281229958630...84.m1423.l2649
Old Jan 14, 2014 | 05:11 PM
jnb5101's Avatar
jnb5101
i used (on steel heads) socket caps. i cut a 1/2" piece off of a hex allen wrench, inserted the piece into the caps in tight locations where the headers curve (because without a bolt head there's plenty of room) and then used an open end wrench to torque the cap. but like i said, these were iron heads and i used lots of anti-seize so i wasn't worried about removing them in the future.
To Exh Manifold Stud Question
