Slim calipers?
I did do some 17" cragar research though, looks like I can get into them for $1080 + $460 tires...a little more than I wanted to spend. What I really need to do is find a way to sell my 15" rally's + tires and then the 15" cragar ss wheels and then go 17". At this point though it seems like I might be better off to go torque thruster II 15" and just forget 17" and cragars for now.
Here is my problem in a nutshell:
a) have 15 x 8 factory rally wheels on the car now with almost new tires
b) been wanting cragar SS wheels for a while, saw a great deal on craigslist for a 2007 set and jumped on them
c) get them home, won't fit on the hub(a few people had mentioned that they had gotten some of the newer ones to work in a few random threads...I obviously did not get that lucky)
d) so I think no problem, I'll just put on spacer/adapter...but while reading through all of the posts looking for brands/info, people keep mentioning friends who had wheels fly off, kind of sours me on that idea
e) so now I'm looking for solutions
So the possible solutions are:
a) Get hub centric adapters for $100 to $400, take a possible safety risk (I drive on the interstate with this car at 75mph, so you can see my concern over that)
b) Spend ~1500 and get 17 x 8 cragars with tires, sell 15 x 8 cragars and rally wheels and tires for ~700 probably. Cost $800
c) Spend ~750 on torque thruster II 15 x 8's, sell the other stuff to about break even
d) Spend $600 on the calipers + installation for probably $1k, sell rally wheels. cost about $700
It seems like the best solution as of now is either c or b. I was hoping there might be a cheap d) solution or workaround but that doesn't appear to be the case. There doesn't seem to be any case where using the 15 x 8 cragars makes any economical or safety sense, so that's probably off the table. Thanks for everyone's replies, they've been very helpful.
[IMG]
[/IMG]
I'm running Dynalites on my car, and it took some work on my part to get everything (rotors and calipers) to clear the wheels, but I was putting a C4 suspension on my car at the time (ancient picture during fabrication below). You can see here how shallow of a hat I had to use with this suspension, and the caliper was still thin enough to allow me to use stock wheels for street use. The stock C3 rotor hat is much deeper than the ones I'm using, so Dynalites might work out for your application.
I have Wilwood Dynalites on my '69 along with Cragar SS aluminum rims. Good fit, plenty room, no adapters needed. See my sig pictures.
