help identifying this part....
Old Jan 18, 2014 | 04:53 PM
henryr's Avatar
henryr
Default help identifying this part....
i cannot seem to find the part listed anywhere.....
it is the aluminum tubing that goes from the exhaust mani shielding to the underside of the air cleaner intake.
there is no clamp on the bottom side that connects to the valve cover.. should there be ?
anyone know what bulb size / part number for under the hood..off hand ?
tks
Old Jan 18, 2014 | 05:03 PM
henryr's Avatar
henryr
i should add - this is a 78 l48 motor car
Old Jan 18, 2014 | 05:39 PM
docmow's Avatar
docmow
2021 C5 of the Year Finalist - Unmodified
no clamp on either side
Old Jan 18, 2014 | 05:44 PM
Mooser's Avatar
Mooser
The tube is going to be a flex heat pipe or something along those lines, probable listed with the air cleaner parts
check paragon #8710 and 11780k, looks like there should be a clamp at each end
M
Old Jan 18, 2014 | 05:47 PM
sfsvettes's Avatar
sfsvettes
BubbaHut
ZIP EH -449 Air cleaner Pre heater hose
they have the clamps too EH 502
Old Jan 18, 2014 | 06:59 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Owners manual should tell you what bulb goes where.
Old Jan 18, 2014 | 07:35 PM
gbvette62's Avatar
gbvette62
It's sometimes referred to as a "stove pipe".
When doing research for the NCRS 78-79 and 80-82 Judging Manuals, 15-20 years ago, some cars were found with just one clamp at the top or bottom, while others had two clamps. I'm assuming that GM intended there to be two clamps on the pipe, but they may not all have left the factory, with two installed. I'm not sure what the Judging Manual calls for, and I don't have my manuals near by at the moment.
Old Jan 18, 2014 | 07:53 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Default hose
tks
my GM trruck has that hose...no clamp on bottom.
Old Jan 19, 2014 | 08:36 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
My '81 has 1 clamp on the bottom and no clamp on the top...also, the stove pipe is sometimes available at the auto parts store....good luck!
Old Jan 19, 2014 | 08:49 AM
tokim's Avatar
tokim
Like sfsvettes stated it is called a pre-heater hose, and yes, they can be bought at any parts store (quite common, used on many cars in various sizes).
Old Jan 19, 2014 | 03:29 PM
henryr's Avatar
henryr
thanks guys....
tending to think the 1 clamp on top is factory as this is basically a one owner car.
To help identifying this part....
