Rear Diff Case Crack - Can it be repaired?
Old Jan 26, 2014 | 07:16 PM
Acidgypsy's Avatar
Acidgypsy
Default Rear Diff Case Crack - Can it be repaired?
I think I know the answer but I figure I would ask.
The rear case Cover has a crack where the U-bolt for the spring attaches.
the second photo shows the crack from the inside of the rear cover.
Options? Ideas?
Old Jan 26, 2014 | 07:38 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
That is just the differential cover - not the housing - if I am seeing it correctly. Just purchase a new heavy duty cover and gasket.
You can remove the cover and take it to a metal shop where they will heat it then repair it. By the time you are done, you are close to a new cover.
John
Old Jan 26, 2014 | 07:51 PM
Acidgypsy's Avatar
Acidgypsy
John
Thanks John. You are correct. I think I am hearing you say that it can be repaired OR I could replace it. A quick search on fleabay shows one with the exact same crack in it!
http://www.ebay.com/itm/Corvette-Original-Rear-End-Differential-Cover-I-11-4-1963-1977-/150988866281?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette&hash=item2327a342e9&vxp=mtr
Old Jan 26, 2014 | 09:10 PM
Gordonm's Avatar
Gordonm
Get a new HD rear end cover and be done with it. These were a weak assembly from the start. The cost will be about the same if you repair or replace.
Old Jan 27, 2014 | 08:48 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Or.....if you have access to a welding machine and cast iron compatible welding rods.....
Clean the cover with degreaser/grind a I/4" wide groove into the crack on the inside and outside/put the cover in the broiler portion of the oven for an hour/grab it with pliers/ go the the garage and weld the grooves flush inside and out/put it back in the broiler for 30 minutes---then turn the broiler off and let the cover slowly completely cool down in the oven/grind the outside weld smooth/re-drill and re-tap the threaded hole.......
(or buy a replacement cover/save the cracked cover for a future repair)
Old Jan 27, 2014 | 02:03 PM
Zoix's Avatar
Zoix
Default Rearend cover
http://www.muskegonbrake.com/corvett...erential-cover
Old Jan 27, 2014 | 02:15 PM
Go Vette Go
Here is a possible solution:
DIFF COVER
Good luck!
Old Jan 27, 2014 | 03:50 PM
Rally68's Avatar
Rally68
X2 for the Muskegon Brake HD rear cover. Don't buy an original style replacement; as you can see, the original casting is prone to failure--both the ears were cracked on mine. I compared the two units side by side when I rebuilt my diff, and the Muskegon cover is an absolute bargain at $150
Old Jan 27, 2014 | 09:55 PM
loup68's Avatar
loup68
Army
Buy the heavy duty replacement cover. Yours cracked, like mine did 30 years ago, because all of the rear weight of your car is on the spring that bolts to that cover. You do know that if both sides crack, the rear spring can flip out and guess what happens then? Lou.
Old Jan 28, 2014 | 08:53 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Our Heavy Duty Rear End Cover is definitely a good choice. The original covers had a poor design and was notorious for cracking and/or breaking off one of the mounting ears. As said previously, you can always put a new cover on and keep and possibly restore your original.
Old Jan 28, 2014 | 10:44 AM
71scgc's Avatar
71scgc
MB HD Cover. Weighs nearly double a stock cover.
Best Cover.
Yes I have one.
Carter
To Rear Diff Case Crack - Can it be repaired?
