water pump
Old Jan 30, 2014 | 05:41 AM
vette_20's Avatar
vette_20
Default water pump
Heh has any one had any problems with water pump bolts coming loose .
has been happening since i bought car ,came loose about 3 times first thought it was water pump have replaced that now ,i suspect clutch fan but cant see any problems but i dont think you would .did have a bit of vibration the other day but went ,i would like to order new clutch fan but thought i would ask here first to confirm it.
Hope for some help
thanks in advance
Old Jan 30, 2014 | 07:12 AM
oldschoolvette's Avatar
oldschoolvette
Hope for some help
thanks in advance
Random thoughts
1- please verify that you are using new lock washers when you install the bolts
2-please verify that you are torqueing the bolts
3- are the threads on the bolts or block worn / damaged?
Good luck
Old Jan 30, 2014 | 07:20 AM
vette_20's Avatar
vette_20
Originally Posted by oldschoolvette
Random thoughts
Good luck
Yes new arp water pump bolts and washers
and yes torqued them correctly
and motor has been rebuilt inc cleaned and tapped all threads
To water pump
