Alternator Choice?
Old Jan 31, 2014 | 05:54 PM
Vettes Rule's Avatar
Vettes Rule
Default Alternator Choice?
What is everybody's choice for best way to go for a new alternator on 1981
Old Jan 31, 2014 | 07:21 PM
rcread's Avatar
rcread
Unless you need more juice, I'd go with the AC Delco 10SI.
Old Jan 31, 2014 | 07:24 PM
Paul L's Avatar
Paul L
I would just go to your local NAPA. Life-time warranty.
Old Jan 31, 2014 | 07:50 PM
Mike Ward's Avatar
Mike Ward
I still like the 12 VDC units despite global warming, ethanol and Obama.
Old Jan 31, 2014 | 08:09 PM
Sunstroked's Avatar
Sunstroked
I'm into shiny stuff under the hood. For that reason alone I bought a power master polished aluminum. 100 amp. My original was inop anyway. Parts to rebuild them are relatively cheap but polishing the case is time consuming.
Old Jan 31, 2014 | 08:20 PM
Paul L's Avatar
Paul L
Justin Beiber would disagree. And he is controlling the USA and Canada now. Perhaps even Panama.
Old Jan 31, 2014 | 08:29 PM
havesometo's Avatar
havesometo
Don't forget he visited Cuba also.
Old Jan 31, 2014 | 09:39 PM
Mike Ward's Avatar
Mike Ward
I think he's being subjected to mind control from that monkey he abandoned in Germany. No other 19 year old with too much money, too much fame and insufficient slaps upside the head has ever done such crazy things in the history of the world.
The yoots today are revolting.
Old Jan 31, 2014 | 10:04 PM
speedreed8's Avatar
speedreed8
O.P. if its a stock setup i would go with whats on it. trade it in at NAPA or have a local alternator / starter shop rebuild / test it.....
Old Feb 1, 2014 | 10:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I would just go to your local NAPA. Life-time warranty...
Same here. Been there, done that. I had a long talk with Justin Bieber, but it appears not to have done any good.
Old Feb 1, 2014 | 10:55 AM
Mike Ward's Avatar
Mike Ward
You mean he couldn't convince you to smarten up and act your age?
Old Feb 2, 2014 | 09:53 AM
Easy Mike's Avatar
Easy Mike
...You mean he couldn't convince you to smarten up and act your age? ...
The opposite. He suggested I try to act his age. He wanted me to go to Panama with him. I'm out of sun screen, so I begged off.
Old Dec 10, 2022 | 02:09 PM
godabitibi's Avatar
godabitibi
Another common problem for overcharging depending on wiring is the ignition key to alternator signal. This is what the regulator read as voltage. If there is any parasitic resistance on this wire it will read lower voltage and compensate by higher voltage output until it reads the correct one.
Old Dec 10, 2022 | 04:03 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Myself, I like and run a TuffStuff brand alternator. Hard to pass up American made.
depending on your current and your planed accessories you may wish to bump up your amperage. And then of course your wiring.
With twin electric fans and a EFI system I run a 140 amp alternator and it is working well in my application.
To Alternator Choice?
