Seam sealer
Old Feb 2, 2014 | 01:58 AM
Aumie's Avatar
Aumie
Default Seam sealer
Is the SEM seam sealer ok to use in the cab/fender seams?
Old Feb 2, 2014 | 08:30 AM
bondoboy's Avatar
bondoboy
Yes, unless it says to not use it on fiberglass. Contact the manufacturer if you're unsure. Are you talking about the 2 part sealer or the 1 part caulking tube? If the 2 part, you will need the special gun to use it, but it will be more durable than anything that was used from the factory.
Old Feb 2, 2014 | 01:01 PM
Aumie's Avatar
Aumie
Idk what to use. Mine was cracked so I dug it all out and was curious what was best to use. I'd been looking off and on for something online and in the dye thread I started everyone spoke highly of SEM dye. I search for it and boom there is seam sealer too!
Old Feb 2, 2014 | 04:04 PM
Cjustin's Avatar
Cjustin
for sealing body panels I have been using tigerseal and it is great stuff! I haven't used it on anything corvette yet but it would be worth a look.
Old Feb 2, 2014 | 08:14 PM
bondoboy's Avatar
bondoboy
I'm not sure about vettes, but older gm cars used a white latex type caulk, I believe. Any modern urethane based sealant is an improvement.
Old Feb 2, 2014 | 11:53 PM
Aumie's Avatar
Aumie
Thanks for cluing me in to tiger seal. I did some research and a lot of folks swear by it. And it's great for fiberglass!
To Seam sealer
