882 heads
Old Feb 3, 2014 | 08:56 PM
holden7896's Avatar
holden7896
Default 882 heads
Hi, I'm gonna be building an engine somewhat soon. It's gonna be a 355. I'm looking to make at least 350 hp, but I'd like the torque to be a bit more. I'd also like it to have some low end power, since my rear gears are so high. One of my friends says he'll give me his 882 heads for $300. They've already got a valve job, and the valves are 2.02 intake, 1.6 exhaust, so they're bigger than stock. Would these heads be worth the money, and get me to my power goals? This is also gonna be a budget build. Thanks!
Old Feb 3, 2014 | 10:10 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
ive gone 12s with them...are they 300 bolt on and go? if so 200 is the right number, you can buy new alum sbc heads shipped to you complete for 650.....not worth putting money into the 882s
Old Feb 4, 2014 | 01:13 AM
LB66383's Avatar
LB66383
What pistons are you running? The 882 heads have 76cc combustion chambers. If you don't match the pistons to the heads, you could end up with a very low compression ratio and a disappointing amount of power. I agree that a set of aluminum heads for a bit more money would be a better investment, but it you're intent on the 882s, I have a set of fairly new ones lying around my garage that you can have for the cost of shipping.
Old Feb 4, 2014 | 08:40 AM
bashcraft's Avatar
bashcraft
He's not your friend.
Old Feb 4, 2014 | 09:40 AM
Tooonz's Avatar
Tooonz
When I was looking into heads for our 79, I was advised against them. The reasons I was given were #1 there are prone to cracks, #2 they were called smog heads. My interpretation of that was they were designed more for emissions than horsepower. Even though the valve size is impressive, there are better alternatives.
blunblk68's Avatar
blunblk68
nail on the head there!!! 882`s are prone to cracking and just not a real good head overall.
like others have said invest in some descent aftermarket heads!!
Old Feb 4, 2014 | 09:44 AM
blunblk68's Avatar
blunblk68
if your 355 is gonna have flat top pistons (no dome) go with a 64-67 cc head and bump your compresson ratio to 9.5-10:1 it will make a big differance also the heads are like the lungs for your engine the better it can breath the better/faster it will run.
the best money you can spend on an engine build is in the cam and heads
Old Feb 4, 2014 | 10:00 AM
holden7896's Avatar
holden7896
I'm definitely gonna be running flat top pistons. And where can I get aluminum heads for $650? I've seen them for that much each, but maybe I'm just looking at the wrong places! Thanks for all your help!
Old Feb 4, 2014 | 10:11 AM
blunblk68's Avatar
blunblk68
you dont need aluminum that is basicly to shave fractions of a second for drag cars etc.. yea they look cool but dont actually preform any better than cast heads jmho
i found a good combo for street engines is 355 with flat tops a comp cam 280 magnum cam and lifters, a good set of heads like world or dart or patriot.
these are a good head for the money!!
http://www.ebay.com/itm/sb-sbc-Chevy-Chevrolet-67cc-World-Products-SR-Performance-Heads-2-02-1-60-042660-/151224676916?pt=Motors_Car_Truck_Parts_Accessories&hash=item2335b17234&vxp=mtr#ht_272wt_916
Old Feb 4, 2014 | 10:45 AM
corvettenorway's Avatar
corvettenorway
Old Feb 4, 2014 | 10:51 AM
corvettenorway
http://purplesagetradingpost.com/sum...fo/heads1.html
Old Feb 4, 2014 | 10:58 AM
BOSTONCAMARO
um all over the 'auction site'
I was mistaken, $599 shipped....haha
actually these are newly listed, have seen same before for $650...if the 882's were rebuilt, ready to go, I could see throwing them on for $200 but not a penny more, they are not worth spending any money on IMHO. That being said, years ago, when the aftermarket heads were not attainable for such cheap prices, we did a set up as I had springs, they went on my friends 383 8.75 to 1 or so SBC in a 87 GTA, he went 12.80s with 3.27 gears! Many of the early SBC performance books refer to them as a 'mild or moderate performance head'
Here is an 882 top and a later model 305 head on the bottom, see the orange arrows, that is where material is missing, making these lightweight heads. I do not think they made the 882 in a lightweight version. Of what I understand, many of the 882's are an exact copy of the 881's which were used in Corvettes I believe and had 1.60 and 2.02 valves.
Here is some more information from a forum:
"Not all late 882 heads were created equal. Many LATE 74 Z28 and Corvette L-82 applications used a Hi performance cast version of the 882 head . True, Most early 882's were equipped with 1.94 intake valves and low rpm valve train. BUT... I have in fact seen & owned them Cast as 882 exact same head as a 881 , late 74 882 issues had the good thick iron casting , high speed valve train and 2.02 valves, hardened valve seats all FACTORY INSTALLED . These will run the higher RPMs easy and can be ported to make even more HP with little work.....at an afordable cost. Al Covin 's book CHEVY BY THE NUMBERS notes/verifies this oddity of the 881 & 882 Castings being excactly the same late in the 1974 year . Just sold an extra set of the good 2.02 /882 cast heads . Many times the nicer HP 882 heads can be picked up cheap as people don't realize which version they have."
http://www.ebay.com/itm/Sbc-Small-Block-Chevy-Aluminum-Heads-210cc-64cc-350-head-Pro-Series-/310865236268?pt=Motors_Car_Truck_Parts_Accessories&hash=item486103112c&vxp=mtr
BOSTONCAMARO
http://www.ebay.com/itm/ProComp-Sbc-Small-Block-Chevy-Aluminum-Heads-190cc-64cc-Angle-/310865239507?pt=Motors_Car_Truck_Parts_Accessories&hash=item4861031dd3&vxp=mtr
Old Feb 4, 2014 | 10:59 AM
BOSTONCAMARO
you get the picture...
http://www.ebay.com/itm/SMALL-BLOCK-CHEVY-GM-SBC-350-ALUMINUM-CYLINDER-HEADS-210cc-w-550-Lift-Springs-/380802716745?pt=Motors_Car_Truck_Parts_Accessories&hash=item58a99c5449&vxp=mtr
Old Feb 4, 2014 | 11:02 AM
qwank's Avatar
qwank
head technology has a come a long way in the last 30 years. I don't know why anyone would use those heads for a performance build when decent heads are so inexpensive now.
you can get used Vortec heads for the same price.
Old Feb 4, 2014 | 11:05 AM
Tooonz's Avatar
Tooonz
I picked up a nice set of 461 heads for around 375 all done on ebay. that youtube link was informative.
Old Feb 4, 2014 | 11:10 AM
BFI's Avatar
BFI
You don't need alu. heads. You also don't need big ports. World products makes some good cast iron heads for what you are wanting to do. I would stay away from the 882's. Bigger isn't always better, in fact for the street and if you are wanting low end torque STAY away from too big on the ports.
Old Feb 4, 2014 | 11:31 AM
holden7896's Avatar
holden7896
Yeah I definitely get the picture. I could easily make more power for not much more money. How big would too big be on the ports?
Old Feb 4, 2014 | 11:58 AM
BOSTONCAMARO
basically port size, runners etc higher volume goes along with higher compression, bigger cams, higher rpm operating range
personally I would go with aluminum, in theory, they will make a bit more power due to its heat dissipation properties, less apt to detonate based on that and they are lighter and you can tell everyone you have aluminum heads! haha
A good cam, 10 to 1 compression and a pair of heads like the 190cc ones on the 'auction site' I don't think you will be disappointed as I think it will be a strong running street car, everyone has their own opinion, yet none of us are wrenching on John Force's car.
These would be great, being 180cc, but they are bare and also are more money, I think you would be fine with the 190cc heads I posted earlier.
To 882 heads
