I was reading in one of my engine rebuilding books about using a lubricant on the threads of some bolts and decreasing the torque values by some percentage over the dry recommendations.
My question is, as I reassemble the suspension on my 74, should I be using some sort of lubricant on the threads of all the fasteners, or should I torque them to specs dry. I know that I should use Locktight Red on the control arm bushing bolts according to Vansteel (using poly bushings).
The only place that I've seen where lubricant is used on washers and threads are the head, main and rod cap bolts. In those cases, the specs specify that they are for lubricated threads, washers and bolt heads ( or nuts). Remember that these fasteners will always be in contact with lubricant. I wouldn't lubricate nuts and bolts on your suspension though.
Dry vs wet torque is another one of those arguments that isn't going to be solved here.
In non-critical use, target torque values are usually only within about 25% of optimum. Factor in the questionable accuracy of the torque wrench (particularly the clicker style ones), thread condition (paint, rust, damage, etc) and you can see where the difference between wet and dry torque values quickly becomes negligible.
In critical areas (some motor work etc) most manufacturers of these precision/specialty type fasteners have tested their fasteners and provide conversion charts or values to allow for the use of torque values instead of the stretch measurement.
There are special tools for measuring the stretch of the fastener rather than the torque but not in most peoples tool boxes.
That being said, and in this case for the suspension, just try to compensate for any torque needed to turn the bolt and toque to whatever the factory numbers are.
I was a former Mech. Instructor at a nuclear facility and we trained our tech. on this issue. We had a training aid with string gauges that showed the difference when using lubricant and not using lubricant on fasteners. I would always use lubricant on fasteners, the friction points will rob you of the true torque required for a given application. I even lub my wheele lug nuts before installing.
I use the "Next-time" Rule: If it was rusted tight this time---a dab of grease--for the next time.
(For those who switch to stainless nuts/bolts....a small amount of lube must be applied to mating surfaces---stainless-on-stainless is more than likely going to seize together)
I've lubed the lug nuts my self (used high temp lithium grease) but then read you should never do this. Now I don't know what to think. After all, grease and oil collect dirt then water, and we're trying to prevent corrosion right?
I'll agree that torque values are an indirect representation of bolt stretch, and we probably only get a crude approximation. It's not a simple topic...
