Wheel dollies
Old Feb 18, 2014 | 10:15 PM
rcread's Avatar
rcread
Default Wheel dollies
I brought some wheel dollies home from work today so I could slide my '71 sideways in the garage. We're getting a new water heater installed tomorrow and I wanted it away from that area. I have the engine ready to come out and the clutch and shifter linkage are disconnected. These dollies would work great if I lived next door to an NFL offensive line who could come over to help, but I don't. The dollies worked ok with my TR6 on them, but that car's a lot lighter. Can anyone make a recommendation for a dolly that could be pushed around by one person? I think mine only have bearings in the swivels and not the wheels.
Old Feb 18, 2014 | 11:40 PM
cagotzmann's Avatar
cagotzmann
Have a look at these.
Auto Dolly
I purchased 16" units so I can use them for my 1978 or 2010 GS.
Here they are on the 2010 GS Pushed the car in the corner without help. The main problem you will have is pushing the car up hill. Most garage floors are sloped downward towards the main doors. To move the car up hill you need to slide side to side starting at the rear.
The most important part, the floor must be smooth! and dont push on the body parts. I push or pull on the wheels only.
Old Feb 19, 2014 | 12:18 AM
69FASTFUN's Avatar
69FASTFUN
I purchased a set at Barrett Jackson in January and the ones that I bought are aluminum so they are light second they have nice casters and that is the key they also have roller bearings and have a grease zerts.
Old Feb 19, 2014 | 05:23 AM
Luke in SA's Avatar
Luke in SA
Has anyone used the GoJak wheel dollies ?
http://www.zendextool.com/gojak/
Old Feb 19, 2014 | 08:32 AM
Camivette's Avatar
Camivette
rc
Before you use the dollies you need to grease the bearings and the wheel slide. I know they were new but it will make all the difference in the world especially if they are the HF variety
Old Feb 19, 2014 | 08:41 AM
DKDunn04's Avatar
DKDunn04
I have some Tire Skates, and they are great. My 130lb wife can push the car around easily.
Old Feb 19, 2014 | 08:56 AM
MrJlr's Avatar
MrJlr
Originally Posted by Camivette
rc
Good Tip
My HF dollies creek and groan and it's a bit of a PITA to move around....I think I'll shoot some white lithium grease on them!
Old Feb 19, 2014 | 11:55 AM
lvmyvt76's Avatar
lvmyvt76
I like the idea of the wife pushing the car around, no grease needed then!
Old Feb 19, 2014 | 12:24 PM
AdamMeh's Avatar
AdamMeh
I have not tried the ones mentioned above, but I can say that the ones from Harbor Freight are horrible VERY hard to move the car around by yourself. Save yourself and get some good ones - $$ well spent.
Adam
Old Feb 19, 2014 | 12:34 PM
Tim 1973's Avatar
Tim 1973
Adam
Adam, Thanks for letting us know. I have thought about purchasing them from HF the next time they went on sale.
DK,
Not that I could talk my wife to come and push a car around in my shop. Where did you get the Tire Skates? And can you post a picture of them. I would like to get some that I could use on my 37 and Vette , but they need to be able to handle some wide tires....
I like the ones that have the built in jacks but sure they do not come cheep.
Tim
Old Feb 19, 2014 | 12:45 PM
chevygod's Avatar
chevygod
I have a set of HF ones (1500#, silver color), so far OK but these have been heavily lubed and get spray lubed everytime they get put under something. Smooth concrete is also a huge plus.
Old Feb 19, 2014 | 01:27 PM
keithinspace's Avatar
keithinspace
I have the HF variety and have been pleased GIVEN THE PRICE. That's always the qualifier.
I would personally stay away from ones that don't have metal wheels. I tried to 'cheap out' and use some of the smaller furniture dollies I had on hand and they were useless. Wheels flat-spotted. I don't care HOW hard the plastic is, I can't imagine that not happening with anything other than a metal wheel over time.
It isn't REALLY easy, but I've always been able to tug on my bumpers and spin the car around however I wanted.
If I didn't have bumpers, then I guess I'd have a little more of a problem.
Old Feb 19, 2014 | 01:46 PM
jcloving's Avatar
jcloving
I have the HF variety and the wheels are off center. They would roll over and rub the pivot point near the plate. I've slowly ground them down and now they work as they should.
Old Feb 19, 2014 | 03:24 PM
wisoutlaw's Avatar
wisoutlaw
Auto Dolly
I've got these same ones and they work great. Try setting the casters in the direction you first want to move the car before you put the car on them. That way they're not fighting you. They're much easier to turn when they're rolling than from a dead start.
Old Feb 19, 2014 | 05:26 PM
Tim 1973's Avatar
Tim 1973
Do you think you can put wider then 16" tires on them?
Old Feb 19, 2014 | 05:58 PM
gbvette62's Avatar
gbvette62
The GoJaks are fantastic. They're easy to use, roll well, work great and you don't need to jack the car up. Also, they're available in an assortment of different capacities, and for a variety of tire widths.
The big drawback to them is their cost, as they start around $250 each! Unless you have a large collection of cars, or a shop where they'd get used regularly, it might be hard to justify the price.
Old Feb 19, 2014 | 07:07 PM
cagotzmann's Avatar
cagotzmann
My Tires on 2010 GS are 325/30-19. about 14" tread. You cannot go much wider on mine or the tire will ride on the bolts for the wheels. Max I think is about 14.75" inch tread.
Old Feb 19, 2014 | 07:28 PM
Tim 1973's Avatar
Tim 1973
I'm running 33 x 21.5-15 on the rear of my 37...
Old Feb 19, 2014 | 08:32 PM
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
I only know of one person who has tried these, but he likes them a LOT.
http://www.harborfreight.com/1250-lb...lly-67287.html
To Wheel dollies
