ok,drilled the rivets out and got hub off,ripped the emergency brake shoes out and took off the four nuts that hold swing arm to rest of hub and got that off now how in the hell do you get brg holder off the shaft,i tried pullers and a BFH but it wont budge.
No offence but in reading your post yesterday about removing the rotor, it seems you're trying to do this job blindly with no books, knowledge or experience.
Rebuilding the rear wheel bearing assemblies is one of the most complex tasks and requires several hundreds of dollars worth of tools and measuring equipment.
Do a search, get some books and do what most end up choosing- send them out to be rebuilt.
Using a BFH will result in many tears.
have no choice about taking it apart the bottom brg holder is broke where the shock bolt goes thru,the other side im leaving alone
i had to use a 12ton press to get mine apart. BFH and bearings dont mix..... and like mike said it takes about $200 worth of setup tools @ bearings , seals to repair it.
