My driver's side courtesy lamp switch for my 71 coupe finally stuck for the last time the other day so I ordered a new one. Problem is the little thin connecters on the end of 2 wires that plug into the back of the switch are broke off where they bend over the edge of the nylon housing. Now there is nothing to make contact w/the switch. Have checked parts stores & have not been able to find these particular connecters. Any help or recommendations would be greatly appreciated.
Reason: Did not include year.
You will need the special crimp pliers that work for those connecters to properly crimp them... Should be able to find at any electronics hardware store.
Thanks, That is good to know. I am beginning to believe that Corvettes are as bad as boats when it comes to spending money on this & that.
