Easy Striping
Old Feb 21, 2014 | 02:38 PM
Jack605's Avatar
Jack605
Default Easy Striping
Went out to clear my mind from work and decided to strip the top, I only had a 4" flat blade here in my tool box at work this is about 15 minutes of work.
Old Feb 21, 2014 | 04:33 PM
Brandons72vette's Avatar
Brandons72vette
Are you going to repaint it or cove it in vinyl? Looks like fun project.
Old Feb 21, 2014 | 04:50 PM
Jack605's Avatar
Jack605
Going to go with the vinyl, the car is going to be repainted by a body shop I have a relationship with just as soon as they have an opening for me.
Old Feb 21, 2014 | 08:09 PM
Lupigiato's Avatar
Lupigiato
Love black vinyl on the hardtop. Are you installing the vinyl, or outsourcing that? Would love to see pictures of that process. Good luck!
Old Feb 22, 2014 | 01:46 AM
Brandons72vette
I was hoping you were going to say vinyl. I love the way the colors and textures contrast. It just helps it stand out that much further next to boring cars of today like the sentra, prius, and civic.
Old Feb 22, 2014 | 09:12 AM
Jack605's Avatar
Jack605
I think the vinyl will look great against the white car. I am planing on doing it myself the top needs a little work first it looks like someone either dragged it across the floor or used a grinder on the back edge of the top.
Old Mar 1, 2014 | 09:59 AM
Jack605's Avatar
Jack605
95% of the top has been striped the rear window has been removed in one piece.
The question I have is with these scratches, I swear the PO dragged the top across his garage several times. and what I should do with the tips as well I am planning on getting the chrome caps but I am wondering how hard it would be to rebuild them out of fiberglass.
Old Mar 1, 2014 | 11:21 AM
pacecar620's Avatar
pacecar620
Jack - I'm no body man, but geezy peezy, it looks like you're going thru a helluva lotta extra work on a top that you're gonna cover in vinyl anyhow. Couldn't you just sand it down to the primer coat, fill in any scratches/gouges and then have the vinyl installed? Just curious. Anyway, I look forward to seeing the finished project, sounds killer!
Old Mar 1, 2014 | 11:50 AM
Jack605's Avatar
Jack605
Maybe, I started playing around with the razor and the paint came off easy. The scratches I am pretty sure I will just use filler the wing tips on the back I am not so sure about I think they need to be fiberglass because so much material is gone.
To Easy Striping
