Factory A/c Question
Can someone with A/C knowledge give me a list of needed parts?
VIR valve or POA depending on what was originally installed, vacuum lines.
Your looking at probably over $1000. in used parts.
Find a car in a local wrecking yard and prepare to spend a half day pulling all of it
A set of used compressor brackets will cost you at least $100, and about $170 for new ones.
A condenser is $275, and the brackets go for about $30 each new or $40-45 for a pair of used ones.
The main hose assembly is $110, while most of the other lines, you'll have to find used.
Personally, I wouldn't bother with putting in a used compressor, condenser or main hose assembly, so your looking at about $600 just for those items. Your easily looking at another $300-400 in parts, and that's if the evaporator, heater box/core/hoses, VIR, switches, etc are all still there. Don't forget to figure in freight, if you can't get them locally, plus the cost of having the system charged, once it is installed.
