New problem. Need help...
Old Mar 4, 2014 | 04:31 AM
MANUL's Avatar
MANUL
Default New problem. Need help...
Hi, everybody! New problem at mine Vet. The gear shifting cable rusted. The day before yesterday I disconnected the coulisse from a box, but I can't pull out a cable. For this purpose it is necessary to remove the panel of additional devices. Prompt as it to remove? I turned off screws from above (number 1 on a photo), but it clings to a middle part (number 2 on a photo). Whether it is necessary to remove the panel of the emergency brake, if yes that as? Thanks.
Old Mar 4, 2014 | 06:21 AM
cvm's Avatar
cvm
Default screws
Someone will chime in w/ more until then don't go further on the vertical panel as there are 2 screws on the outside edge hidden under N 2.
N 2 needs to be removed to gain access to these screws.
GL
Old Mar 4, 2014 | 07:33 AM
MANUL's Avatar
MANUL
how to remove the panel number 2 ???
Old Mar 4, 2014 | 07:37 AM
540 vette's Avatar
540 vette
There are 2 screws that hold that panel to the center shifter panel. At number 2. You have to remove the seats to get the side panels off and the screws are right at that spot.
Old Mar 4, 2014 | 08:33 AM
MANUL's Avatar
MANUL
Understood. Thank you. And the bottom, under the car it possible to somehow remove the shift cable? Do not really want to remove the chair.
Old Mar 4, 2014 | 08:47 AM
Pete79L82's Avatar
Pete79L82
GL
There are 3 phillips head screws (circled in red) that hold each carpeted side panel in place. I am able to get mine out without removing the seats by using a stubby Phillips screwdriver.
Then you will have access to the screws (#11 and #19) that hold the center console plate. You will also need to unfasten the heater control (#16) from the console plate before you remove it.
Final note- You will need to unscrew the shift ****, there is a small spring under the ****. Be careful not to loose it.
Also, when you remove the center gauge panel, there is a light at the top of the panel. Be VERY careful at this point. The light will try to catch on the dash pad and if you are not careful, it can catch the dash and crack it.
Old Mar 4, 2014 | 08:57 AM
Pete79L82's Avatar
Pete79L82
Here is a illustration of the shifter cable. You may not have to remove the console plate or the center gauge panel to change the cable. Just remove the right side carpeted panel for access.
Remove #13, #9, and #19 from inside the car. Then remove #9 and #25 from underneath and the cable should come out from the top.
Pete
Old Mar 4, 2014 | 09:32 AM
MANUL's Avatar
MANUL
yes, it's picture open my eyes. Tomorrow will be remove panel.
Old Mar 4, 2014 | 11:08 AM
MANUL's Avatar
MANUL
Cable removed, he died (((Does somebody have the original part number? Scheme No. 9 completely, as I understand it?
Old Mar 4, 2014 | 12:33 PM
Pete79L82's Avatar
Pete79L82
Item #10 Cable complete 77-82 original GM part # 357746
To New problem. Need help...
