Sticking caliper?
Old Mar 7, 2014 | 06:15 PM
Stingray Wes's Avatar
Stingray Wes
Default Sticking caliper?
I got my 79' out for the first cruise of the year and towards the end of my cruise I started noticing what seems to be possibly a sticking caliper...the brakes feel and sound like they are grabbing and sticking in the rear. I notice driving up and down the driveway at slow speeds it makes quite a bit of noise in the rear.....what was interesting is when I first took off for the cruise the front right was doing it bad to the point where it sounded like a ran over something....I'm guessing a mixture of rust and so on the rotor from sitting over the winter.....but the front went away and 20 miles later the back is terrible..
Any ideas on fixing sticking calipers if my thoughts are correct in what this noise is?
Thanks all for your time!
Wes
Old Mar 7, 2014 | 06:35 PM
mrvette's Avatar
mrvette
IF the calipers are dead stock, they can hang up fairly easy, given the age and DOT3 fluid.....so when you tear it all down to check for maybe someone has most likely exchanged the OEM calipers for Stainless Steel lined calipers, you are in luck if so.....then to change all of the rubber brake hoses....blast the lines clean/clear with brake cleaner, and air jet, rebuild calipers, and refill with Silicone DOT 5 fluid....NAPA has it, most other stores don't......Silicone forstalls rust....
Old Mar 7, 2014 | 08:12 PM
Arkyvette's Avatar
Arkyvette
Every time I drive a vehicle that has sat for a time, I do a "confidence check" on the brakes. That is simply mashing on them a few times from a decent speed. This will serve two purposes, cleaning off the brake discs and letting you know if something is wrong before you need to use them in a real panic stop. I have had some that took quite a while to eat the rust off and quiet down, especially in the rear. Might give it a few good hard stops and see if the noise goes away.
Old Mar 7, 2014 | 08:18 PM
Dave J's Avatar
Dave J
Sticking calipers are the classic symptom of internally collapsed brake hoses. They may look good on the outside, but the damage occurs inside. When they collapse, it prevents the brake fluid from flowing back through the lines. Hence, sticking calipers.
Good luck.......
Old Mar 7, 2014 | 09:51 PM
Duane4238's Avatar
Duane4238
Good luck.......
I'm in agreement with Dave J. It's most likely the brake hoses have collapsed. It happened on my '72 a few years back. Replace your hoses, first, then if that doesn't solve the problem you can start work on the caliper rebuild. Good luck.
Duane
Old Mar 7, 2014 | 10:57 PM
jcuprisi's Avatar
jcuprisi
I must respectfully disagree with the last three words. DOT 5 will not forestall rust. In fact, since it does not absorb moisture the brake fluid will float on top of any moisture in the system. This means that the moisture will be where we don't want it...in the calipers where it can boil and cause localized corrosion of the aluminum pistons. C3's are designed for DOT 3. The fluid is designed to absorb moisture and disperse throughout the fluid. The main disadvantage of the moisture is lowering the boiling point of the brake fluid. The best thing is to flush the brake fluid every Spring when we put our cars back on the road, or at least yearly for our friends in the warmer Southern climates.
Old Mar 8, 2014 | 12:08 AM
Stingray Wes
Thanks to all of you for your time. Sounds like I need to start with the rubber lines and work from there....this is something I haven't witnessed before and my 69' didn't have this problem but maybe the calipers and / or lines were replaced at some point on it.
Thanks!!!l
Wes
Old Mar 10, 2014 | 06:57 PM
Stingray Wes
Ok guys... A couple more questions before I tear into this thing.....I was driving it more over the weekend and every time I went out in the car the caliper would not stick until after several times of applying the brakes...then once it started sticking it would stick until I parked the car for a couple hours and got back in it...and then same routine....
Question is...does this still sound like a collapsed hose to you guys?
Question #2 if so...what kind of troubles am I going to run into changing this thing out? Easy to bleed the system back? I've changed several sets of pads and rotors on various vehicles but have never done anything where I'm opening up the system so I assume I will have to bleed after completed..
Please shed some light....I'm all ears and would like to get this done - it's driving me crazy and I'm sure not doing my brake system any favors either.
Thanks guys!
Wes
Old Mar 10, 2014 | 07:15 PM
ddawson's Avatar
ddawson
Make life easy and get the Motive Brake Bleeder and a large C-Clamp. Also a pack of vacuum caps. Also a set of Flare Nut wrenches.
When you disconnect the hardline at the body pop a vacuum cap on the hardline to keep the fluid from running out.
Then you can take your time replacing the softline. While you have it all apart check the calipers for any sticking piston.
Depending on age I would rebuild or replace the calipers.
Once it's all back together bleed the brakes with the Motive Bleeder. Having a rubber mallet is good too to tap the caliper during the bleed.
I use a clear rubber hose over the bleeders into a bottle to catch the old fluid.
Old Mar 10, 2014 | 07:26 PM
Arkyvette's Avatar
Arkyvette
Soft hoses for sure.
Old Mar 10, 2014 | 07:38 PM
Dave J's Avatar
Dave J
Classic case of YES!
Everyone has their own idea of the best way to bleed brakes. I like the gravity method. Also lets me have a few adult beverages in between!
Old Mar 10, 2014 | 08:23 PM
Arkyvette's Avatar
Arkyvette
The soft lines in the rear go right into the short hard line sections heading into the rear calipers. Now is the time to change those as well if they are rusty or strip out when trying to free them from the soft line. Mine were nasty from the elements and stripped out when attempting to loosen them, so I cut them off and replaced both lines and went with all new calipers from the local parts store.
Old Mar 10, 2014 | 08:27 PM
mrvette's Avatar
mrvette
I agree, it's hoses, BUT long as you going trough all the effort to do them, maybe as well pop the calipers apart and see what is what,
and I have been running DOT5 fluid in any car I care about for over 20 years now, never an issue.....OH, BTW, I have never had to change fluids either, always clean/clear.....
Old Mar 10, 2014 | 09:13 PM
Stingray Wes
Thanks for all the input guys.....I truly appreciate it. After getting some nice weather for a change this past weekend we now have another winter storm coming this week so it will be a great time to tackle this project. I'll report back.
Thanks!!!!
Old Mar 14, 2014 | 07:43 PM
Stingray Wes
Ok guys....changed both rubber hoses as discussed and bleed the brakes......still getting this noise when brakes are applied and released. It's very loud and you can feel it in the rear wheels when rolling at low speeds....I still believe it to be a sticking caliper because I can run the car down the road at 60mph with no issue.....once I stop and then take back off it starts making the noise. It seems the slower I go the louder it gets.....
Thoughts? Calipers next or something else going on?
Thanks for your time guys.
Wes
Old Mar 14, 2014 | 08:43 PM
Mike Ward's Avatar
Mike Ward
You've convinced yourself it's the brakes. Why can't it be differential, u-joint or wheel bearings?
Old Mar 14, 2014 | 08:50 PM
Stingray Wes
Mike - it absolutely could be something else....I don't know for sure. I'm looking for guidance or suggestions on what direction to go next.
What throws me to the brakes is I can run down the highway with no noise, vibration or anything.....noise starts after brakes are applied several times about 10 minutes into a drive but quits once I get going again. Comes back when I stop and take off again.
Ideas, recommendations, suggestions?
Thanks guys
Old Mar 22, 2014 | 10:10 PM
Stingray Wes
Ok guys here's the latest....I have now changed rubber hose to calipers, steel line from rubber hose to calipers, new calipers, rotors, brake pads...rear wheel bearings were changed before I bought the car approximately (6 months ago).....I still have this "grabbing" sensation coming from the rear after I stop and take back off. Never does it at speed. Feels just like a sticking caliper but obviously that wasn't the answer.....I'm lost. What else would make this noise and vibration only after taking back off from a stop? I wouldn't know what in the differential would do this but I'm lost. Please help!!
Any ideas?
Thanks for your help guys.
Wes
To Sticking caliper?
