painting frame
Old Mar 8, 2014 | 05:20 PM
ernest3203's Avatar
ernest3203
Default painting frame
could i use truck bed liner to paint frame instead of por 15,walmart sells it at 45.00 a gal
Old Mar 8, 2014 | 05:58 PM
SB64's Avatar
SB64
Default paint
You may need more information like is the body off the frame. Is it sandblasted to raw metal, what are you looking to do with the frame. The bottom line is you can probably use almost anything. It all depends on what you are going for. Hope this helps
R
Old Mar 8, 2014 | 06:06 PM
John68's Avatar
John68
Cruising
cheaper choice than POR-15 would be Chassis Saver ..works the same an costs less
Old Mar 8, 2014 | 10:21 PM
ernest3203's Avatar
ernest3203
R
its a 79 vette,body already off frame,sandblasting it now,looking for an economical way to paint frame and i know the bedliner is tough s##t
Old Mar 9, 2014 | 07:00 AM
SB64's Avatar
SB64
Default paint
I know I had my frame powder coated but I did not like the shine so I sanded it with 400 paper, went to Lowes and got Rustoleum etching primer and sprayed the entire frame. Then came back with Rustoleum semi gloss black. Total cost $75.00. Seems to have a fairly thick coating.
Old Mar 9, 2014 | 09:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ernest3203
...could i use truck bed liner to paint frame instead of por 15...
You don't have to use either.
Old Mar 9, 2014 | 09:46 AM
John68's Avatar
John68
Cruising
We use this on pretty much all the frame at the shop .. you can find it for less than $100 a Gallon
https://www.google.com/shopping/prod...d=0CLIBEKYrMAc
Old Mar 9, 2014 | 10:46 AM
LT-1 kid's Avatar
LT-1 kid
after the frame is blasted, I then roll and brush on rustoleom semi gloss oil base , turns out perfect, and well protected
To painting frame
