Ready to start framing.
Old Mar 9, 2014 | 03:43 PM
twinpack's Avatar
twinpack
Default Ready to start framing.
As soon as the snow is gone, I will start framing my 26x28 detached garage. I would like to see how others have set up theirs. I am getting one shot at this with the wifes blessing and want to make the most of it. It is heated by radiant, will have a 100 amp service. Looking for cabnet layout, work bench, lighting, air line, floor finishes. You get the idea. Please post pictures and give suggestions. Much appreciated.
Peter
Old Mar 9, 2014 | 03:55 PM
tokim's Avatar
tokim
Check out www.garagejournal.com
Old Mar 9, 2014 | 06:23 PM
my 76 ray's Avatar
my 76 ray
Consider using trusses that will give you more ceiling height in the center so you will have room for the lift that you will want next. Some types are: scissor, cambered and vaulted.
Old Mar 9, 2014 | 09:05 PM
twinpack's Avatar
twinpack
Good site. Thanks
Old Mar 9, 2014 | 09:07 PM
twinpack's Avatar
twinpack
Will be using trusses with attic space. I should end up with a ceiling height around 10'8".
Old Mar 9, 2014 | 09:31 PM
CAN-AM69's Avatar
CAN-AM69
Congratulations and good luck with your build! We'll be starting ours as soon as the old pole barn is down.
Old Mar 10, 2014 | 08:33 PM
68conv455's Avatar
68conv455
Add a few feet to the size and make it a three car. Or three x two high = 6 car
Old Mar 10, 2014 | 09:27 PM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
I'm thinking average lifts are a little higher then 10'8"? IIRC they're just over 11'?
Old Mar 10, 2014 | 09:28 PM
Don Rickles
2017 C3 of Year
I'll take the old pole barn!
Old Mar 10, 2014 | 09:59 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Put a sturdy beam and vertical support across half the width of the garage to attach a hoist to.....for the body-lift/ frame-off!
Old Mar 11, 2014 | 06:50 AM
twinpack's Avatar
twinpack
Would have love to go a bit larger but I will take what I can get, 26x28 will have to do.
Thanks for the suggestion. I will do a little research and build with that in mind.
Good thought. I will see if I can manage the beam. I do not want any post in the middle of the garage, so I will see if it is in the budget to span the width.
Old Mar 11, 2014 | 11:48 AM
lvmyvt76's Avatar
lvmyvt76
And plenty of them!!!!!!
Old Mar 11, 2014 | 11:50 AM
BOSTONCAMARO's Avatar
BOSTONCAMARO
I need to build something at my house, my parents have a huge 100 plus year old barn, which we sheetrocked, insulated and is a great work space, but really need something at my house.
Post pics as you build yours please.
Here is the barn...
Old Mar 11, 2014 | 10:52 PM
Indiancreek's Avatar
Indiancreek
If 26X28 is large enough, build it larger. Space just disappears somehow.
Old Mar 11, 2014 | 11:08 PM
CAN-AM69's Avatar
CAN-AM69
It's a big, ugly one that used to be a storage facility for a lumber yard and it still had several hundred pieces of 'real', good, old lumber on the shelves when we bought it. We're going to give it to a crew for taking it down and getting our lot ready for our new building.
Old Mar 11, 2014 | 11:13 PM
jr73's Avatar
jr73
what he said
Old Mar 11, 2014 | 11:54 PM
Iraqandroll's Avatar
Iraqandroll
2nd Gear
Not much, but your work bench should be built to the height of your bent elbow. If it is just a few inches too small after a prolonged period of time your lower back will let you know it. What ever the electrical layout for outlets, nearly double them. That is what I did in mine and am happy I did.
To Ready to start framing.
Old Mar 12, 2014 | 06:54 AM
twinpack's Avatar
twinpack
Will keep this thought in mind when building the bench. Thanks
I agree, but the foundation and slab are poured and back filled. So I will have to make the best of what I have.
Was really hoping to see pictures of what others have done. Please post pictures of your garage and layouts.
Old Mar 12, 2014 | 06:21 PM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
Consider a 200 amp service.
Air compressor, heater, and welder.
Not much more $ to upgrade.
Also, consider a covered/heated outside(shed) area for the compressor to save floor space for cars. Also, if you buy the trusses with enough pitch so you can walk around(10/12-12/12), you'll have a large area above to build shelves for storage. It'll need some stairs, too.
BILL
Old Mar 12, 2014 | 06:35 PM
TWaldo's Avatar
TWaldo
Put the compressor in the attic...
