Question on fender key activated alarm
Old 03-13-2014, 07:33 PM
RichardC77
RichardC77's Avatar
Default Question on fender key activated alarm
Was the alarm system on the 76 and 77 corvettes a standard item or was it an optional item? I've heard both opinions. Thanks for any info.
Old 03-13-2014, 10:18 PM
Mod75
Mod75's Avatar
Finalist 2021 C3 of the Year - Modified
Not sure? I will check my invoice sheet tomorrow.
Old 03-13-2014, 10:32 PM
gbvette62
gbvette62's Avatar
Received 2,078 Likes on 1,344 Posts
The alarm was made standard, in 1971. All Corvettes built since 1971, have come with some sort of factory installed alarm system.
Old 03-13-2014, 10:38 PM
kjb13
kjb13's Avatar
Really? If my '81 has one, I have no clue where it is.
Old 03-13-2014, 10:46 PM
briankeery
briankeery's Avatar
Your hood, T-tops, and doors are all contacted for an alarm. Separate horn by the cruise transducer. Driver door key lock arms and disarms. It's discussed in your owners manual.
Old 03-13-2014, 10:47 PM
Mod75
Mod75's Avatar
I agree, checked my invoice and delivery sheets, no mention of alarm system as an accessory.
Old 03-14-2014, 01:32 AM
gbvette62
gbvette62's Avatar
The alarm was optional on 68-70 Corvettes. Starting in 71, it became part of the car's standard equipment. On 68-73 Corvettes, the alarm switch was located in the center of the taillamp panel, above the CORVETTE letters.
When the flexible rear bumper was added in 74, the alarm switch was moved to the left front fender. It remained in the left fender, until part way through the 77 model year, when it was incorporated into the driver's door lock. All 78-82 Corvettes had the alarm switch as part of the driver's side door lock.
On 77-80 Corvettes, the alarm is armed and disarmed by using the key in the driver's side door lock. On 81-82's, the alarm is disarmed with the key in the driver's door lock, but armed by locking the doors with the power lock switch (on cars with PL's), or when locking the doors with the lock button, on cars without power locks.
Old 03-14-2014, 08:13 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,470 Likes on 1,249 Posts
Cruise-In II Veteran
...Really? If my '81 has one, I have no clue where it is...
...Your hood, T-tops, and doors are all contacted for an alarm. Separate horn by the cruise transducer. Driver door key lock arms and disarms. It's discussed in your owners manual...
Yep. Your 1981 owner's manual explains it and tells how to arm and disarm it. For 81, the stock alarm system includes a starter interrupt.
To Question on fender key activated alarm
Quick Reply: Question on fender key activated alarm
