Brake question
Old Mar 15, 2014 | 10:49 AM
georgiaboy's Avatar
georgiaboy
Default Brake question
Changing out my brake calipers and the new ones come with a bag with the new pin that holds the pads and two copper rings that look like the old compression rings that spark plugs used to have. Haven't seen these before and the old ones didn't use them. Where do they go if anywhere?
Old Mar 15, 2014 | 11:17 AM
georgiaboy's Avatar
georgiaboy
On the way back from another trip to the parts store for some more "while you are at it" stuff, I think I figured it our. The only place they could go is on the bolts that hold the calipers to the backing plate. There are currently lock washers there and I think I will just leave them.
As the guy said .... "I was wondering why the baseball was getting larger and larger and then it hit me".
Old Mar 15, 2014 | 11:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Washers go on the brake hoses at the caliper. If yours were missing, someone has played with the brakes in the past.
Old Mar 15, 2014 | 11:23 AM
Brcmpbl's Avatar
Brcmpbl
If they are copper they might be the brake hose washers. Usually they come with new hoses, but I can see them coming with the calipers in some circumstances. The caliper bolts use heavier metal lock washers, not copper.
Old Mar 15, 2014 | 11:24 AM
Brcmpbl's Avatar
Brcmpbl
Mike, we were typing at the same time!
Old Mar 15, 2014 | 11:30 AM
Easy Mike's Avatar
Easy Mike
What's that saying? "Like minds think alike" or some such.
Old Mar 15, 2014 | 01:55 PM
georgiaboy's Avatar
georgiaboy
The brake lines are all flared fittings and don't have a mating surface that the ring would fit on.
Old Mar 15, 2014 | 01:59 PM
redvetracr's Avatar
redvetracr
are you sure?
btw, he said brake HOSE not brake line
Old Mar 15, 2014 | 02:57 PM
Brcmpbl's Avatar
Brcmpbl
Not brake lines. Brake hoses. Two different things. I suspect they look like this:
http://www.parts123.com/parts123/yb....5Z50000050G~~~
Old Mar 15, 2014 | 04:47 PM
georgiaboy's Avatar
georgiaboy
Guess I should have said 78. No place on the back calipers for the rings. All flare fittings. Just got to the front. The rubber hoses on the front have a flat mating surface where they hook to the caliper that takes a copper o ring. Caliper probably fits several years and maybe some have the rings on the rear. Thanks for all the replies..
Old Mar 15, 2014 | 05:47 PM
Brcmpbl's Avatar
Brcmpbl
You got it. Glad you got it sorted.
To Brake question
