Steering column-Turn signal part???
Old Mar 22, 2014 | 05:03 PM
blueshoremario's Avatar
blueshoremario
2nd Gear
Default Steering column-Turn signal part???
Hello, I was dismantling my steering column to reach the 4 main bolts and tighten them due to the column being wobbly. Heard that this is a very common situation, Got the bolts tightened down down also with some thread-lock. However the issue is as I was re-assembling the column, a part came out and I have no idea where it came from. I was just slipping the center column (that holds the turn signal mechanism on the left) and this small metal clip or spring fell out. Not sure if it was from something else or if it is in fact from the turn lever mechanism. I have searched and searched for a exploded diagram of the turn signal mechanism to no avail. Does anyone recognize this part??? Thanks in advance.
-Blueshoremario
Old Mar 22, 2014 | 05:22 PM
'75's Avatar
'75
Do a search on this site or google for Jim Shea's papers, lots of info!
Old Mar 22, 2014 | 09:03 PM
Lupigiato's Avatar
Lupigiato
Your AIM should show all components. I agree with '75, Jim Shea is the expert on steering system assembly and has published a lot of helpful white papers. You might also try going to Wilcox websites they offer year specific white papers and install guides which may offer additional info. I have two early C3's and that part you show is not familiar, so might be a later C3 component. Good luck!
Old Mar 22, 2014 | 09:59 PM
'75's Avatar
'75
That may be the clip for the key warning buzzer switch.
Old Mar 22, 2014 | 10:11 PM
'75's Avatar
'75
I've got Jim's papers , pm me with your email if you want them. Their full of info about the job you're doing.
http://jimshea.corvettefaq.com/wp-co...v24MY20123.pdf
http://jimshea.corvettefaq.com/wp-co...v03JL20121.pdf
Old Mar 23, 2014 | 01:01 AM
my 76 ray's Avatar
my 76 ray
I think that's a spring that goes under the "rack" that's moved by turning the ignition switch. It holds it up so the gear doesn't jump a tooth. Here's a picture of the rack.
http://willcoxcorvette.com/popup_image.php?pID=27249
Old Mar 23, 2014 | 07:07 AM
Jim Shea's Avatar
Jim Shea
Yes, I think that it is the rack preload spring. Here is a blowup of the column head. You can see the spring right under the switch actuator rack in the top schematic.
The rack, sector, and the "grasshopper" spring are in the Wilcox pic above but not your leaf preload spring.
Jim
Old Mar 23, 2014 | 03:27 PM
blueshoremario
2nd Gear
That's it.
It is the "Pre-load Spring". I had to remove the center pivot pins (again) to gain access to it. Thanks to everyone's input!
Waiting for the new top bearing and the Horn Contact Retainer to arrive so I can finish out the re-assembly. Then on to the next with is testing and repairing the tach and the speedometer. The speed works, but the odometer does not move. It just makes a clicking sound.(annoying)
Thanks!
Old Mar 23, 2014 | 04:04 PM
Lupigiato's Avatar
Lupigiato
Originally Posted by blueshoremario
That's it.
Thanks!
great and helpful folks on this forum.
Old Mar 23, 2014 | 04:12 PM
georgiaboy's Avatar
georgiaboy
I love this forum. I have had my C3 for 27 years and my learning curve is still going straight up!!!!
To Steering column-Turn signal part???
