Knock off wheels
A friend just bought a C3 that is fitted with what appear to be genuine knock off wire wheels. He wants to keep the car "original" and plans to sell the wire wheels. Any idea what they could be worth?
I know I should post this in the C2 section, but you guys always come through with the right advice.
Regards from Down Under.
aussiejohn
http://www.ebay.com/itm/67-B-O-WHEEL...-/201027615495
Knock-offs came available on Corvettes from 1964-66, with some reportedly available from dealers in 1963.
I do like the look of the knock-offs mounted on a C3. Western Wheel did make a 15x8 wheel that I think looks pretty mean. I think I'll be throwing mine back on this year, give the P02s a break.
I used to see the c2 aftermarket "stock" knock off for sale all over,
And I recall a few aftermarket wheel outfits made the adapter style knockoffsthat the wheel part did knock off,
Now days in the ghetto thug status donk world wire/spoke knock offs are very common....
I'm not sure exactly what you mean by "the wheel part did knock off..." but this is the adapter that is used for the knock off wheels. Under the knock off center cap is a safety pin that gets removed, then give the spinner a hit with your lead hammer.
I consider "real/true" knock offs being cars with spindles that have the big threaded part in the center and not some adapter bolted to the 5 studs.
The ones like in your picture to me are still a fake knock off, because part still bolts to the same hub a standard wheel could,
but they are not as fake as putting a spinner cap on a hub cap or mag wheel that still runs it's several lug nuts to remove the wheel.....
I would like to see a picture of a P48-optioned hub.
Things like factory wheel options are not my savvy.
I was under the impression that the knock offs like in your picture were a knock off conversion or adapter not a true knock off like race/euro cars had were as the spindel would only accept the correct knock off wheel, there was no adapter to take off and run a lug nut style wheel,
I was pretty sure my dads old jag was like this .
Besides being jazzyed because I would love to find a set of the aftermarkets in a 10x15 and 9x15 I really shouldnt have said a word here....c2 owners are savvy enough to know what is what.
Western Wheel did make reproduction K-H wheels that were 15x8. I also like the look!
82SE wheels are some of my favorite.
GM probably opted to use adapters to allow for cost effective wheel options. If only pin drive wheels were available, then different drive hubs would probably have been used.
This is not Corvette specific
-the modern term "knockoff" has become mainstream but it is really the correct term for the "knockoff spinner" not the wheel. Single nuts were and are also used.
-the original wheels are either called "pin drive" or "spline drive" wheels (no adapters used)
-lots of British (mostly) cars used spline drive wheels with no adapters, Astin Martin, Austin Healy. MG, Jag, Lotus and so on.
-Kelsey-Hayes back in the day did build pin drive wheels for racing other than those for Corvette.
-all original street Cobras (with leaf springs) came with pin drive wire wheels
-the use of a drive adapter increases the track width so original and adapter pin drive wheels are not the same.
-I think it's just the winged knockoff spinner that is outlawed, nuts are still good.
