Rear Wheels Stuck
Old Mar 31, 2014 | 11:39 AM
maverickmk's Avatar
maverickmk
Default Rear Wheels Stuck
My rear wheels are stuck on the axle. I would rather not beat on them as I have read in other threads.
I have these wheels -
Do you think a brake drum puller like this will work?
Old Mar 31, 2014 | 11:43 AM
russianhomie119's Avatar
russianhomie119
have you tried just giving it a kick at the bottom of the wheel from the inside? just make sure you are using a solid floor jack
Old Mar 31, 2014 | 12:13 PM
Gilded_Splinters's Avatar
Gilded_Splinters
A good whack with a dead blow mallet on the inside bottom should knock it loose. Be sure to hit the rim, not the tire as the tire will absorb the energy from the mallet blow.
Old Mar 31, 2014 | 12:31 PM
my 76 ray's Avatar
my 76 ray
That brake drum puller will likely damage the rims more than a blow with a dead blow hammer.
Old Mar 31, 2014 | 12:49 PM
Mike Ward's Avatar
Mike Ward
Put the car back on the ground, loosen the lugnuts a few turns and roll the car back and forth.
Done.
Old Mar 31, 2014 | 12:54 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
That works. I have the aluminum wheels and mine had become stuck from sitting a very long time before I bought it.
Old Mar 31, 2014 | 02:56 PM
maverickmk's Avatar
maverickmk
Done.
Nice, I'll give that a shot
To Rear Wheels Stuck
