Help! Radiator Drain Plug C3 1969
Old 04-02-2014, 09:52 PM
Captainkvan
Captainkvan's Avatar
Default Help! Radiator Drain Plug C3 1969
I was trying to drain my Radiator using the drain plug. I got a 9/16 socket on it and a back up wrench on it. I tried turning it and the drain plug seam where the plug screws into moved a little and started dripping coolant around the seam. I think I cracked the seam and created a leak. My question is can I remove the support that the radiator mount screws into without damaging anything. If I remove it I think I can get into that spot and solder it with my propane torch and repair it without removing the radiator.
Any suggestions will be helpful Thanks!
Old 04-03-2014, 04:16 AM
terrys6t8roadster
terrys6t8roadster's Avatar
bite the bullet, pull the rad, leak on bottom? probably need to turn upside down to do a good job to get any coolant away from affected area. besides you can always do some touch up work with the rad out. T
Quick Reply: Help! Radiator Drain Plug C3 1969
