Voltage gauge not working
Old Apr 6, 2014 | 10:13 PM
Parsons957's Avatar
Parsons957
Default Voltage gauge not working
My gauge isn't working.Should i just replace or what could be the issue?
Old Apr 7, 2014 | 11:54 AM
MelWff's Avatar
MelWff
Did you test the wire harness to see if there is a break?
Old Apr 7, 2014 | 09:24 PM
Parsons957's Avatar
Parsons957
Actually, i was able to get it working after i realized that when i replaced the circuit panel for the gauges, i didn't connect the resister the right way. After i switched that up, it worked just fine. Rookie mistake. Thanks for the help though. Now on to the next project. Power antenna...
To Voltage gauge not working
