What is this ???
Old Apr 7, 2014 | 11:35 AM
1978vett's Avatar
1978vett
Default What is this ???
I have been trying to figure out thr vac ports on my carb and discovered this hose .. It isnt connected to anything .. It comes up from under the drivers side fender... Does any one know what it is and exactly where it needs to be connected ?? Thanks for your help ..
Old Apr 7, 2014 | 11:48 AM
MelWff's Avatar
MelWff
looks like it should run to the vacuum advance on the distribtuor
http://willcoxcorvette.com/product_i...3aac4b8f411f38
Old Apr 7, 2014 | 11:54 AM
1978vett's Avatar
1978vett
Thanks for your reply,, This hose runs down under the fender on the driver side,, it is connected to something under there,, I'm trying to figure out what it's connected to under there and what the other end needs to be connected to... The vac advance is already connected...
Old Apr 7, 2014 | 12:00 PM
maverickmk's Avatar
maverickmk
I think it's this canister.
Old Apr 7, 2014 | 12:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Apr 7, 2014 | 12:34 PM
BKarol's Avatar
BKarol
The top of the canister on a 78 looks like this (other years are different)
Old Apr 7, 2014 | 12:42 PM
1978vett's Avatar
1978vett
I'm not sure what that is but that is where the hose runs to and its connected to the top port on the left ...,, The other end is not connected to any thing ... Heres another picture that shows the pcv conections..
Old Apr 7, 2014 | 01:19 PM
1978vett's Avatar
1978vett
I guess I just need to know where to connect the end thats not connected... Does it the fuel vapor canister need manifold vacuum or port vacuum ? Thanks for all of your replies..
Old Apr 7, 2014 | 01:44 PM
qwank's Avatar
qwank
mine connects to the elbow on the air cleaner housing
Old Apr 7, 2014 | 02:34 PM
1978vett's Avatar
1978vett
Thanks for the reply,, it says control vacuum tube on my canister,so I guess that would be connected to ported Vac on the carb ??
Old Apr 7, 2014 | 04:12 PM
1978vett's Avatar
1978vett
Thanks everyone for the replies,, it really helps a lot...
Old Apr 7, 2014 | 04:13 PM
qwank's Avatar
qwank
I don't know, you don't have that elbow on your air cleaner? I'm thinking it sucks the fumes into the engine from the air cleaner and burns them.
Old Apr 7, 2014 | 04:19 PM
1978vett's Avatar
1978vett
I'm not sure either,,,, it says controled vacuum on the end that is connected to the canister,,, not sure but i'm kind of thinking it might mean that it should connect to ported vacuum on the carb..Just guessing though,, thanks for your reply
Old Apr 8, 2014 | 03:38 PM
dembo's Avatar
dembo
Isn't it supposed to go to the TVS switch (blue thing) installed in the waterneck?
The canister is supposed to vent when the engine is at operating temp
Old Apr 8, 2014 | 04:01 PM
1978vett's Avatar
1978vett
On my 78 the egr valve is connected to the TVS switch ,,the switch is connected to port vac on the carb.. My TVS is in the intake manifold. Thanks for your reply ..
Old Apr 8, 2014 | 04:27 PM
dembo's Avatar
dembo
This might help? There's more then one TVS switch.
Willcox page
Old Apr 8, 2014 | 05:00 PM
1978vett's Avatar
1978vett
Willcox page
Thats a good diagram,,, it looks more like what I have.. My EFE switch is in the same place as the one in the diagram.. It isn't hooked up to anything because someone had removed all of that when they installed headers on it.. Thanks for posting that..
Old Apr 8, 2014 | 10:57 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
From the 79 shop manual, same as 78................
That hose you show in your pic goes to the T.
Old Apr 9, 2014 | 08:20 AM
1978vett's Avatar
1978vett
Thanks very much that helps a lot... Is the vac. advance connected to manifold vacuum where it is connected at the carb ?
To What is this ???
