Advice for a first time C3 Owner? Lessons learned...
Hello Everyone,
I’ve been lurking on the C3 forum for some time reading just about everything I can. This coming weekend I pick up my 1973 vette! I’ve wanted a corvette of this vintage for about 30 years and simply decided it was time. Not getting any younger,… childhood dream,… it is beautiful, … 4 speeds are good for the soul… you know the drill!
A comment and a question.
First, I simply want to say “thanks” to everyone who is part of this community. I feel like I know some of you simply by reading your posts and help you’ve provided others. The “what to look out for before you get your first vette” posts really, really helped me. I think the former owner was surprised when I climbed over, in, under and around the car like a hyperactive monkey with a flashlight, jack, jack stands and tools looking for frame / birdcage rust, evidence of Bubba, etc. It helps you avoid a nightmare (and perhaps gives the impression you know what the heck you are doing so your offer seems more reasonable;-) ).
The question: Most of you have been here at least once and I’d love to learn from your experiences. If you had it to do over again, what would be the first thing you’d do with your new C3 vette?
I PLAN on doing NOTHING at first and just drive it to get a feel for what is fine, what needs attention, etc. before I start taking stuff apart. There are some minor cosmetic issues and things to clean but nothing mission critical right now.
If it matters for my question: I do not care about extreme stock. The original motor has been lost to time and the car has had a few things replaced here and there. I plan to keep it generally stock looking but have no problems with improving the 40+ year old technology with a modern ignition, beefed up/modern suspension, brakes, etc.
There will be LOTs of other question (I’ll research them first here before asking!) as I get to know the vette but figured answers to the above question will be very useful.
Thanks again.
Larry
Houston, TX
Thanks again.
Larry
Houston, TX
Received 1,470 Likes
Cruise-In II Veteran
Tune it and drive it.
Congratulations.
Congratulations.
Good one! Usually, it's the other way around... "I picked up a Corvette and I started noticing it had a lot of (pick one).
A) Rust.
B) Leaves and mice nest in the engine compartment.
C) Worn Interior parts.
D) neglected maintenance.
A) Rust.
If I had to do it all over again, I wouldn't have jumped in feet first and tear the whole thing apart. I should've upgraded a little at a time and at least drove it during the process. It's going on 8 years and all I've done is work on it and dream.
I drove my car down the street and back. That was 20 + years ago. Seems like my car was always getting pushed into the corner while I had to fix something else. Everytime I turn around I am upgrading something. Now I am just trying to get it on the road to enjoy and work on it in between.
383 Crate, full exhaust, 5 speed..... Drive it like I stole it....
What I learned:
1) Check the frame birdcage carefully. ( Mine was good)
2) Check the rear wheel bearings and U-joints. Wheel bearing replacement can be expensive.
3) Dont buy a smog car if you plan to do a monster motor... DOH!
4) Buy the best driveable car you can afford.
What I learned:
My approach was:
Make it stop
clean underneath
Preservation underneath
clean
tune up
clean some more
Fix more as budget allows
With 36000 it doesn't need much but time takes a toll
Make it stop
clean underneath
clean
tune up
clean some more
stop first, then go
also a first timer, i picked up my 79 in october. i had just a few weeks before she was put in storage, so in that time i had the oil/filter changed at my local shop and we did a pretty good underneath survey at that time. i did a lot of reading here and on other sites about flat tappet oils and chose Mobil 1.
i suppose condition varies somewhat, but in my case the body/frame/birdcage are very nice but the mechanicals need to be addressed.
my plan was to make sure the brakes and front end/steering are in tip-top shape, then do a full service and tune, clean the interior, then preserve underneath.
over the winter i've wire-brushed the rotors, replaced all calipers and pads, cleaned/rinsed and repacked the wheel bearings, new wheel seals, lubed all zerks, changed the belts, changed the power steering fluid,
replaced the fuel filter, and replaced the hood cross-cable.
she'll be out of storage this week. next up will be having the trans serviced, flush the coolant with new lower hose (upper is new). then spruce up the interior.
this site has been a tremendous resource and i got a GM service manual with my c3, so most of the work will be on me. lower on the list are replacing the tach board, sending out the radio for repair, fixing/replacing the heater control unit (sticks). i'd like to install some hush-mat under the carpets, and replace the pass. side door pull.
i enjoy tinkering, and figure she'll be where i want her to be in about 2 years time. and good luck w/your ride!
bob
bob
What I did:
Change all fluids, so I knew what I had.
Made it stop.
Steroids rack and pinion.
Refurbed the seats
Allignment
New tires
New front wheel bearings. (Rears are being done now, 7 or so years later)
Gas and go!
Have fun!
Dodosmike
Made it stop.
Refurbed the seats
Allignment
New tires
Gas and go!
Have fun!
Dodosmike
