81 temp
Old Apr 16, 2014 | 02:27 AM
kbrin's Avatar
kbrin
Default 81 temp
my 81 runs from 120deg to 220Deg approx (as shown by temp guage on console) I also hear a slight metalic sound. how can i verify the water pump is bad, and what temp should it run??
Old Apr 16, 2014 | 08:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your owner's manual explains operating temperatures. 195 - 210 is normal. 220 is not overheating.
The common sign of a failed/failing water pump is coolant loss from the weep hole.
Are you losing coolant?
Old Apr 16, 2014 | 08:35 AM
C376FL's Avatar
C376FL
I know when my water pump was going bad, I heard a noise coming from under the hood. When I checked I looked for water at the pump, found none. So I grabbed the fan, and it wiggled I knew I had found the problem, bad bearings.
Larry
Old Apr 16, 2014 | 09:16 AM
kbrin's Avatar
kbrin
Default C3 water pump
Larry
I am still working on getting an owners manual, car didnt have one.
Its good to hear that 200-220 temp is ok and it never gets near red warning mark. the punp seems to have no wiggle and is not weeping water that i can see. I first thought the "tinging sound" was the ac compr but am now pretty sure its the pump.
To 81 temp
