Do I need a resistor?
Old Apr 18, 2014 | 12:59 PM
MMJ's Avatar
MMJ
Default Do I need a resistor?
Hi, I am working on my 69 Vette with a L46 motor. All the wiring diagrams I have seen don't show a resistor. Mine has one on there. Is it supposed to? Someone had electronic ignition on it at one time and I am going back to points, I don't know if that makes any difference. Thanks for any help.
Mark
Old Apr 18, 2014 | 02:55 PM
MelWff's Avatar
MelWff
You should have a dual wire set up on the + positive side of the coil. One of those two wires is a resistance wire. Test with a voltmeter to make sure they still are live.
Old Apr 18, 2014 | 04:38 PM
MMJ's Avatar
MMJ
Thanks for the help. The two wires you are talking about (looks like a red one and a white one) are connected to one side of the resistor. Then a black one comes off the other side of the resistor and goes to the coil. What happens if the wires are the resistance type wire and they also go into a resistor? Does that just cut way down on your fire?
To Do I need a resistor?
