Water pump
Old Apr 18, 2014 | 03:40 PM
GreenDream's Avatar
GreenDream
Default Water pump
How do I tell if I have the long or short water pump? 1974 SBC
Thanks,
Old Apr 18, 2014 | 04:09 PM
gerry72's Avatar
gerry72
If it's the stock (or replacement stock...not likely you still have the factory pump on the car), it is neither a short or long. It's a 1971 and later Corvette pump. While it looks like a short pump, the dimensions are slightly shorter than a traditional "short" pump.
Old Apr 18, 2014 | 04:25 PM
GreenDream's Avatar
GreenDream
Thank you..
Old Apr 18, 2014 | 10:38 PM
Vette-kid's Avatar
Vette-kid
Thought it was the other way around...71-82 Corvette water pump is slightly longer than a short pump (by 3/16") and uses a 3/4 shaft rather than a 5/8.
Old Apr 19, 2014 | 09:15 AM
gerry72's Avatar
gerry72
Indeed; you are correct.
To Water pump
