Help, power windows.
Old Apr 24, 2014 | 03:02 PM
James Granger's Avatar
James Granger
Default Help, power windows.
Before I start ripping stuff apart... My power windows in my 75 corvette both went out... They just stopped working. They are stuck in there current position of almost all the way up. I know it's not the motors because they were working GREAT literally 2 days ago. They don't budge or make a noise when I press the switch to go up and down. What could be the problem? Is it a relay? A fuse I'm blind and can't see? Thanks much!!
Old Apr 24, 2014 | 04:16 PM
James Granger
Okay, now my blinkers aren't working. The oil pressure is at S at the end of "oil press". Is it a relay? If so where is it?
Old Apr 24, 2014 | 05:00 PM
oledave60's Avatar
oledave60
The power window wiring harness plugs into the main fuse block with two wires and these run to the relay which is mounted under the console. There is no other fuse in the wiring.
I have no idea why the blinkers would quit at the same time.
Old Apr 24, 2014 | 05:06 PM
James Granger
thank you thank you! This will help tremendously and i think its just a coincidence and my fuse may have blown.
Old Apr 24, 2014 | 10:31 PM
James Granger
Okay, problem solved.... Do not ask me how or why... It's got a 350 TBI motor but has the same wiring... The fuse for my gauges went out and my directional signals (blinkers) and for some reason when I put new ones in it fixed my windows. Again, dont ask me, just happy it is fixed.
To Help, power windows.
