front suspension
Old Apr 27, 2014 | 10:53 AM
tomgaz's Avatar
tomgaz
Default front suspension
I am replacing upper and lower controls arms and springs and shocks I can't get the springs to sit in correctly. please help what am I doing wrong.
Old Apr 27, 2014 | 11:18 AM
The Punisher's Avatar
The Punisher
Pictures would help
Old Apr 27, 2014 | 12:28 PM
SB64's Avatar
SB64
Default springs
Pics would help. Just finished doing all of that. More info also. Why do you think spring is not sitting right.
Old Apr 27, 2014 | 12:59 PM
tomgaz's Avatar
tomgaz
Default suspension
spring is hitting the frame when I am pushing up on the lower control arm.
Old Apr 27, 2014 | 02:31 PM
79VetteNoob's Avatar
79VetteNoob
Just curious, what type of bushing did you go with?
Old Apr 27, 2014 | 02:58 PM
tomgaz's Avatar
tomgaz
Default suspension
I bought everything together from a forum member. The bushings look OEM.
Old Apr 27, 2014 | 03:06 PM
Ralphbf's Avatar
Ralphbf
The top of the shock HAS to be in place or else it's a no-go.
I pulled mine apart 3 times before I got it right.
Set the spring in place, put a floor jack on the lower arm.
Hold the spring in place while someone else jacks it up.
You may want to put the shock in so you can use it to judge
if the spring is in the right location. ..... Good Luck.
I've done this a few times on other cars and never had this much trouble.
Ralph
Old Apr 27, 2014 | 08:34 PM
tomgaz's Avatar
tomgaz
Default suspension
The car sits great. It is sitting lower then the old suspension did. If someone can send me their email so I can share some pics.
Old Apr 28, 2014 | 02:12 AM
Ralphbf's Avatar
Ralphbf
Open a Photo Bucket account.
Then it's free and easy to share and post photos.
photobucket.com
Ralph
To front suspension
