Question
Old Apr 27, 2014 | 01:27 PM
1978vett's Avatar
1978vett
Default Question
There is a tube from the passenger side valve cover that connects into the air filter housing ... Can some one tell me what it is for ?Motor is a 78 L82... Thanks for any info..
Old Apr 27, 2014 | 01:43 PM
LB66383's Avatar
LB66383
That tube and the PCV valve are the positive crankcase ventilation system. Fresh air is pulled into the inside of the engine through that tube. The oily vapors from the inside of the engine are pulled into the carburetor through the PCV valve, mixed with the fuel and air, and burned.
Old Apr 27, 2014 | 03:10 PM
1978vett's Avatar
1978vett
If I go with a aftermarket breather would it be ok to put a plug in the valve cover ?
Old Apr 27, 2014 | 05:39 PM
LB66383's Avatar
LB66383
Not OK. A lot of aftermarket air filters come with fittings to attach so you can run a hose from the valve cover to the air cleaner. Or, you can get a chrome breather that will fasten onto the valve cover.
Old Apr 27, 2014 | 06:46 PM
1978vett's Avatar
1978vett
Thanks for the replies ....
To Question
