Front ride height
Old Apr 29, 2014 | 12:05 PM
1978vett's Avatar
1978vett
Default Front ride height
My 78 L82 has 255/ 60 15s front and back .. The front is approx 29 1/2 inches to the center of the front fender arch and 29 in the rear fender arch .. It doessn't look bad this way but I would like for the front to be a little lower... I'm wondering if the front springs are possibly for another car that someone used to make it sit a little higher .. Does any one have any thoughts on what might have been done ? I know it is just guessing but I can't think of anything else that would raise it that much.. Thanks for any ideas ..
Old Apr 29, 2014 | 04:49 PM
MelWff's Avatar
MelWff
what spring is in the back and how are the spring bolts nuts set, rear height maybe adjustable, picture might help
Old Apr 29, 2014 | 06:00 PM
1978vett's Avatar
1978vett
I put new bushings in the rear spring bolts, and just to experiment I added some washers also.. When I put the car down from the lift the rear was some higher than the front end... Then when I drove it ,, it seemed to almost immediatly settle to where it is now..
Old Apr 29, 2014 | 07:04 PM
FireballXL5's Avatar
FireballXL5
Yea, after being jacked up when you put it down you've got side pressure on each tire, moving it forward/ back a little bit(10+ feet) will allow it to settle and give you a better look at where the ride height really is...
Old Apr 29, 2014 | 08:17 PM
1978vett's Avatar
1978vett
The rear height is not to bad .. The front seems a little high ..
Old Apr 30, 2014 | 08:21 AM
1978vett's Avatar
1978vett
Thanks for your replies ..
To Front ride height
