Pink wire
Old May 3, 2014 | 07:37 PM
PURPLEMONKEY's Avatar
PURPLEMONKEY
Cruising
Default Pink wire
Hi all,
I'm currently fixing a few electrical problems under the dash, mainly a rusted fuse box. I've found all sorts of things which haven't been that bad but I can't workout this mystery cut pink wire coming from the gas pedal kick down switch. I know it goes to the trans but how it does go through the main bulk head connector and I can't find it on any wiring diagrams. What does it do and what happens if I leave it disconnected it seems to kick down better than my 66 mustang.
Old May 3, 2014 | 10:17 PM
Mooser's Avatar
Mooser
Probably wouldn't hurt if you mention what year the car is
Old May 4, 2014 | 07:20 AM
PURPLEMONKEY
Cruising
its a 69
Old May 4, 2014 | 08:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the neutral safety switch wiring. I believe your pink is included in the neutral saftey switch harness.
Old May 4, 2014 | 01:00 PM
Cavu2u's Avatar
Cavu2u
For what it's worth, Pink is a battery direct circuit.
Old May 4, 2014 | 01:26 PM
Cavu2u's Avatar
Cavu2u
OOOOOPS.
Bad info above.
Pink wires are IGN powered, not battery direct.
Old May 4, 2014 | 10:01 PM
PURPLEMONKEY
Cruising
Good call, why route two cable paths I'l check the neutral safety switch harness thanks
To Pink wire
