stuck ignition
Old May 6, 2014 | 12:40 PM
ibflyer's Avatar
ibflyer
Default stuck ignition
Looking for a little help. I have had my car, 1973 coupe, L82, for 5 months and been restoring. Has been on jacks for 4 months while doing new interior and paint. Now getting back together, ( what a nightmare finding where everything goes) and tried finally to get started last night. Key is in lock position and 4 sp is locked in reverse. Can not budge key or shifter. New carpet put in, could there be interference with the clutch? Feels like it goes to the floor. Steering wheel is also locked. Pulling light switch does give indicator lights so I know I did not hook battery up incorrectly.
Old May 6, 2014 | 12:54 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Did you try turning the steering wheel about an inch to the left and right rapidly while trying to turn the key to the Run position?
Old May 6, 2014 | 12:56 PM
Mike Ward's Avatar
Mike Ward
Sure you've got the right key?
Old May 6, 2014 | 01:18 PM
ibflyer's Avatar
ibflyer
Same key as before. Did "jiggle" the wheel as I recall other cars this has worked on, but did not try the what sounds to be more aggressive, turning. Will do tonight. Thanks for the help.
Old May 6, 2014 | 01:19 PM
ibflyer's Avatar
ibflyer
Haven't tried to turn it that far. Is there a switch on the clutch pedal that tells the ignition system that clutch is in?
Old May 6, 2014 | 01:57 PM
Texas70's Avatar
Texas70
Could the lock out cable be out of whack?
It goes from the transmission to the lock out arm inside the engine compartment at the bottom of the steering column. Not sure why the transmission would be stuck in reverse unless the cable is connected to the incorrect lug.
Just something else to look at if you have done anything under the car.
Old May 6, 2014 | 02:22 PM
Peterbuilt's Avatar
Peterbuilt
See if the cable is letting the lever (on the steering column)go all the way up.
http://forums.corvetteforum.com/c3-t...lfunction.html
Old May 7, 2014 | 01:53 AM
Ralphbf's Avatar
Ralphbf
This has worked for me.
Put the key in the ignition tap it kind of firm to drive it deeper into the switch and try to turn it.
I was told to do this by a lock smith friend of mine.,
Ralph
By the way, I never had any more trouble with the switch.
To stuck ignition
