Radiator installation
Old May 7, 2014 | 06:27 PM
Blessmyvette's Avatar
Blessmyvette
Default Radiator installation
Can anyone tell me how long it takes to totally reinstall the radiator in an 82 corvette? It was removed and sent to have a small hole fixed and my mechanic just got it back and is putting it back on my car. I am trying to get some idea of how long it takes, weather I can expect it to be finished today or not.
Old May 7, 2014 | 06:52 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
If he is being paid by the job, then probably it will be ready. If he is paid by the hour, then probably not.
Just sayin...
Old May 8, 2014 | 08:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Blessmyvette
...I am trying to get some idea of how long it takes, weather I can expect it to be finished today or not...
Ask your mechanic. He/she can tell you whether they expect to get it finished today.
Old May 8, 2014 | 09:58 AM
BLUDICE's Avatar
BLUDICE
Please let me know what it ended up costing you - I may have to have mine repaired too - '78 - Thanks
Old May 9, 2014 | 12:09 AM
68/70Vette's Avatar
68/70Vette
C3's are not typically radiator replace/reinstall friendly cars. For the early C3 big blocks...torture.
Old May 9, 2014 | 12:44 AM
CanadaGrant's Avatar
CanadaGrant
I can either remove or replace the rad in my 69 big block in just over an hour. I remove the hood and take out the shroud/rad/support as a unit.
Remove the fan, hoses, three bolts on each side of the support, two on the bottom and the brace, one ground strap, tilt it forward and lift it straight up. I get my wife to hold one side of the hood while I bolt it back down.
Old May 10, 2014 | 01:18 AM
Blessmyvette
Labor was 376.04
Coolant. 21.30
Radiator repair 55.00
Total 452.34
Old May 10, 2014 | 07:39 AM
Easy Mike's Avatar
Easy Mike
Labor was 376.04
Coolant. 21.30
Total 452.34
Can't complain.
Old May 10, 2014 | 09:39 AM
BLUDICE's Avatar
BLUDICE
Labor was 376.04
Coolant. 21.30
Total 452.34
Wow, without knowing what had to be repaired on the radiator I would say you were treated very fair. I have heard an average of 6 hours labor plus materials and whatever the radiator cost is. So a thousand dollars is very possible at the high end.
Old May 10, 2014 | 12:19 PM
CanadaGrant
Can't complain.
If you don't know how to do it, it's an obnoxious job. Some people even cut the parts like the shroud to get them back in.
You did OK.
Old May 13, 2014 | 09:39 AM
Blessmyvette
He removed the radiator and sent it to a radiator repair shop in town to repair a small hole in the bottom of it, reinstalled it and added coolant. That's all that's listed on the invoice.
Old May 13, 2014 | 09:41 AM
Blessmyvette
You did OK.
That's pleasant news for a change.
To Radiator installation
