Build Date Question 1968 Roadster
Old May 14, 2014 | 02:43 PM
CCWest's Avatar
CCWest
2nd Gear
Default Build Date Question 1968 Roadster
Hello. Newbie here. I have a 1968 Roadster and I have a question regarding the build date. The data plate indicates the car was built in April of 1968 (D09). The casting number is the correct 3914678. The date code is J307. I was curious to see if this would make sense. It seems like 6 months between the build of the engine and the build date of the car is a bit long and was curious to see if any members would have any insight on that. Everything else is correct as far as the vin matching and the suffix but wasn't sure about the time between. Any help would be greatly appreciated. thanks in advance.
Mike
Old May 14, 2014 | 04:08 PM
TOM65 L76 96 LT1's Avatar
TOM65 L76 96 LT1
Mike, I believe your build date D09 would be Dec. 9 1967 not April 9, 1968, I think H would indicate a April 1968 build date, hope this helps. Tom
Old May 14, 2014 | 04:37 PM
Mike Ward's Avatar
Mike Ward
1968 production began in August so D09 would be November 09 1967.
An engine casting date of October 30 fits well.
Old May 14, 2014 | 05:43 PM
TOM65 L76 96 LT1
I stand corrected, I thought September was the first month of production, with a Nov. production date according to the info in the "Black Book" Mike's 68 should have a vin number between 3411 and 5682
Old May 15, 2014 | 01:01 PM
gungatim's Avatar
gungatim
D09 is 11/9/67. Mine was built a couple days later, D14, so not far off from yours. My VIN is 04664, they built an average 114 per day in November, so your vin should be around 043xx.
Old May 15, 2014 | 03:02 PM
CCWest's Avatar
CCWest
2nd Gear
Default Re: Build Date Question 1968 Roadster
I appreciate all of your help guys. My vin does fall into that sequence so it appears to be correct. There seems to be so many different answers online out there and I am glad to have the knowledgeable people here to help out. Thanks again.
Mike
Old May 15, 2014 | 03:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by CCWest
...There seems to be so many different answers online out there...
Could be....but the only ones that count are here.
April built 68s are coded I. Mine is I20.
To Build Date Question 1968 Roadster
