car sputtering after ignition off
Old May 14, 2014 | 09:19 PM
garym52's Avatar
garym52
Default car sputtering after ignition off
Ok, i'm not a mechanic and this is probably a stupid question, but after working on the timing the last couple of nights, the car has started sputtering/spitting, trying to run after i turn the ignition off. I think it has something to do with the timing but I would appreciate any thoughts/comments. I've done pretty much everything myself on this car, and have been trying to set the timing, but think i might drive the car to a local mechanic. Help would be appreciated.
Thanks - Gary
Old May 14, 2014 | 09:35 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
That's a common problem (run-on) if the idle speed is set too high, or the timing is too "retarded" which requires the throttle plates to be opened excessively to provide the desired idle speed.
What's your idle timing and speed?
Old May 14, 2014 | 10:00 PM
overBlown's Avatar
overBlown
What did you do while "working on your timing"? Did you mess with the carb at all too?
Old May 14, 2014 | 10:12 PM
Mike Ward's Avatar
Mike Ward
Is the anti-dieseling solenoid installed and operating correctly?
Old May 14, 2014 | 10:13 PM
garym52's Avatar
garym52
Idle timing is 15, rpm is about 500, without the vacuum advance connected.
Old May 14, 2014 | 10:17 PM
garym52's Avatar
garym52
lowered the idle a little after i connected the vacuum. didn't touch it besides that. Had the carburetor professionally tuned for my cam/engine build.
can't answering that question because I don't know what that is
Old May 14, 2014 | 10:23 PM
68/70Vette's Avatar
68/70Vette
After I installed my ZZ4 into my 68, I had some engine running issues that I thought were related to timing. I took the car to a garage operated by an old guy who been in business for probably 40 years. My car was a classical case of an early 70's pre-smog car needing a tune-up. He didn't really charge me that much. When I drove the car away from his garage, it was a different car.....a noticeable increase in power.
For the older non computer controlled engines...breaker points, HEI distributor, you need ..sometimes.. a specialist to set the engine up for max power.
Old May 15, 2014 | 09:09 PM
garym52's Avatar
garym52
thanks...I think i will seek out a professional to perform the final tuning of the engine. I really wanted to do everything myself, but my youtube training is failing me this time
Old May 15, 2014 | 10:12 PM
Mike Ward's Avatar
Mike Ward
The anti-dieseling solenoid holds the throttle open at the normal idle speed but closes the throttle to prevent dieseling when the ignition is turned off.
Your AIM shows the solenoid very clearly.
Old May 15, 2014 | 11:28 PM
garym52's Avatar
garym52
thanks for the info, but I can't find it in the AIM for my 1979....I've lived by the aim this whole project, but honestly hadn't even looked at it for this until tonight. again, thanks for the help.
Old May 16, 2014 | 09:45 AM
Mike Ward's Avatar
Mike Ward
Here you go:
http://www.parts123.com/parts123/yb....5Z50000050G~~~
Old May 16, 2014 | 09:50 AM
garym52's Avatar
garym52
To car sputtering after ignition off
