Sumitt Racing alternator bracket
Old May 18, 2014 | 08:47 PM
AirborneSilva's Avatar
AirborneSilva
Default Sumitt Racing alternator bracket
Am wanting to add a little bling to the motor and was thinking of getting this alternator bracket, has anyone had any experience with these? Thanks
http://www.summitracing.com/parts/sme-2001/reviews
Old May 18, 2014 | 09:57 PM
aussiejohn's Avatar
aussiejohn
Default Yes Sir!
G'day,
Yes, I bought one of those, but not for the looks. I could not remove my power steering cap with the standard cast iron alternator bracket and had to loosen the pump mounting bolts, swivel the pump towards the crank and then the cap would come off. After I had checked/added PSF, I had to swing the pump outwards and hold tension on the belt while I tightened the bolts. Not a pleasant experience.
Once I fitted the Summit bracket, I could get the PS cap further out, but still not all the way. I took the bracket off and ground a bit of the aluminum away from the bottom of the bracket about under the middle bolt hole and now have no problems. Maybe a shorter belt would have been the correct way to go, but I'm not complaining about the definite upgrade.
If you don't have a power steering pump, don't bother to read the above.
Regards from Down Under.
aussiejohn
Old May 19, 2014 | 04:38 AM
AirborneSilva
Thanks John, yes I do have a power steering pump and yes it can be difficult to get the cap off. Thanks for the reply
Old May 19, 2014 | 06:54 AM
C3Hawk's Avatar
C3Hawk
If you get one, let me know if the fit is ok. I was thinking of getting one myself to free up space around the PS pump like aussiejohn was saying.
Old May 19, 2014 | 07:13 AM
AirborneSilva
I will be sure to let you know. I hadn't thought about the PS but yes it is a pain to get the cap off and fluid in
Old May 19, 2014 | 10:00 AM
thegazman's Avatar
thegazman
Default thegazman
John... Did you have any problem lining up the drive belt with the alternator?
Old May 19, 2014 | 10:51 AM
AirborneSilva
That's my only concern, there was on review that said something about the pulley's.
I'm getting ready to pull the trigger on it so I hope he or someone speaks up soon...
Old May 19, 2014 | 07:02 PM
thegazman's Avatar
thegazman
Default thegazman
If you buy the alternator bracket let us know how the install goes.
Old May 19, 2014 | 09:35 PM
Lupigiato's Avatar
Lupigiato
I have that bracket in my 68. Today Gordonm installed my power steering so I can't speak to the access to fill the PS fluid reservoir, but the turnbuckle helps tighten the belt.
Old May 19, 2014 | 09:50 PM
TPI BOY's Avatar
TPI BOY
Does everything line up ok
Old May 19, 2014 | 11:19 PM
Ironcross's Avatar
Ironcross
A member makes a excellent bracket....a search can find him or another member may have this information.....
Old May 20, 2014 | 07:25 AM
AirborneSilva
Thanks for the pic lupi
I ordered the bracket yesterday, it shipped last night so I hope I have it before the weekend.
Old May 21, 2014 | 09:04 PM
AirborneSilva
Got the bracket today, it was an easy install and everything lined up well. I will have to pull it apart to polish it, the finish is satin and I want it to shine like the chrome 120 AMP alternator I will have soon. As far as getting the PS cap off it does make it easier to do so that's also a plus.
Old May 21, 2014 | 09:06 PM
Lupigiato's Avatar
Lupigiato
Old May 22, 2014 | 12:02 AM
F22's Avatar
F22
Another good little tidbit of 'tribal knowledge' to add to my noggin!
Old May 22, 2014 | 07:21 AM
AirborneSilva
I had to run to the auto parts to get a shorter belt too, the one I had on it was longer than stock (long story that I wont bore you with), I got one 1/2" shorter than stock and am glad I did. I know 1/2" doesn't make too much difference but it will give me just that much more adjustment. The turnbuckle adjuster is great, you can turn it by hand to tighten the belt but still need a 9/16 wrench to tighten the jamb nuts.
Old May 22, 2014 | 02:05 PM
C3Hawk's Avatar
C3Hawk
Glad it worked out. I was looking at this very part just last week. Now I might have to get one!
To Sumitt Racing alternator bracket
Old May 22, 2014 | 02:11 PM
AirborneSilva
I'm happy with the purchase and install, I'll post some pics after I take it back off and polish it this weekend.
Old May 22, 2014 | 02:26 PM
F22's Avatar
F22
Can you get the PS cap off? That's what I'd like to know, because Aussie John is right, I can't remove the cap completely. I end up using the inspection camera to even look inside! And filling it up is a PITA. Tell us how it does in that area. Inquiring minds, wanna know!
Old May 22, 2014 | 02:30 PM
AirborneSilva
I was always able to get mine off, it wasn't real easy though. It does come off much, much easier so I'd have to say yes you'd be good to go (you'd be able to remove the PS cap to be clear), if you installed this.
