73 vin number problem
Old May 20, 2014 | 09:23 AM
seastar's Avatar
seastar
2nd Gear
Default 73 vin number problem
I have a 73 with this vin on the title (Indiana) and on the plate under the front left of the window.
1z37z3s40#### (hid last four numbers for security)
When I search it I am told the vin is too short by 3 numbers.
Anyone know what the problem is?
Is this a fake vin plate?
Stolen car?
I have owned the car for 20 years.
Old May 20, 2014 | 09:34 AM
davidchristopher's Avatar
davidchristopher
Who exactly told you it's short? it's the correct length from what I can see.
1Z37J3S40####
1Z=Corvette
37=Coupe
J=Base Engine (Yours is a 454, so it's a Z)
3=Model year 1973
S=Built in St Louis
40####=sequence number.
1973 Corvette VIN
Character Position Code Significance
1-2 1Z Chevrolet Corvette
3-4 37 Coupe
5 J Base Engine
5 T L-82 Engine
5 Z 454 Engine
6 3 Last Digit of Model year
7 S St Louis Assembly Plant
8-13 6 Digit Build Sequence Number
Old May 20, 2014 | 10:13 AM
Iceaxe's Avatar
Iceaxe
I'm guessing you or whomever told you was using some web program designed for modern cars, which have a longer serial number.
Old May 20, 2014 | 10:49 AM
joewill's Avatar
joewill
I agree.... whatever tool you are using does not support the shorter VIN numbers from that era.
Old May 20, 2014 | 01:57 PM
seastar's Avatar
seastar
2nd Gear
Right you are!
Thanks to all who replied.
I found a decoder that worked for pre 81 cars.
Old May 20, 2014 | 02:35 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by seastar
...Anyone know what the problem is?...
Probably where you're seaching. You complete VIN will be 1Z37Z3S4xxxxx. The last five digits will be the consecutive unit number.
If you're playing with Carfax, your car is too old to be listed.
Old May 20, 2014 | 02:53 PM
AirborneSilva's Avatar
AirborneSilva
Right you are!
Care to share this decoder?
To 73 vin number problem
