Hood latch wont release
Old May 20, 2014 | 09:36 AM
chevygrl79's Avatar
chevygrl79
Default Hood latch wont release
Problem is on the passenger side, hood latch has pinched the weather stripping that came loose. What is the best way to fix this? I have tried going through the rubber piece like the drivers side has but I cant see the passenger one.
Any help would be greatly appreciated.
Old May 20, 2014 | 10:08 AM
AirborneSilva's Avatar
AirborneSilva
It looks like you have a 79, this may help.
Old May 20, 2014 | 10:13 AM
chevygrl79's Avatar
chevygrl79
This is the method I tried, if it were on the drivers side I could with a lot of effort pull this job off the problem is, myself and two others do not see this on the passengers side as its a very snug fit. Will taking the wheel off help gain access?
Old May 20, 2014 | 10:47 AM
AirborneSilva
No the wheel is too far forward to give you any access and the fender well would also be in your way. I believe that video I posted is on the passenger side. I have a 76 so I'm not familiar with the 79, sorry.
Old May 20, 2014 | 11:58 AM
chevygrl79's Avatar
chevygrl79
There seems to be not enough room to find our way through the gap to the rubber stop, any other suggestions?
Old May 20, 2014 | 12:13 PM
AirborneSilva
If I'm understanding you issue correctly and the weather stripping has gotten caught between the fender and the hood maybe you could have someone pull on the hood release (holding it all the way out - or back if that makes more sense), and have someone pull up on the hood on the passenger side. It sounds to me like it's just wedged closed with the weather strip.
Old May 20, 2014 | 12:28 PM
chevygrl79's Avatar
chevygrl79
We have tried that as well, we really are at a loss on how to get this off its jammed on there TIGHT! I have already pulled on the loose weather stripping and it snapped off at the latch.
Old May 20, 2014 | 12:31 PM
AirborneSilva
Sorry, I'm at a loss. is there by chance a corvette shop around?
Old May 20, 2014 | 12:46 PM
chevygrl79's Avatar
chevygrl79
Not near where I am at the moment, it's in a regular garage atm. So tools are not a problem, it's the knowledge of the different ways to go about this. I have seen where someone online took a wheel off to get to the same problem but not seeing a lot out there about that so wasn't sure just how hard it was going to be, they did say it took quite some time to do it that way.
Old May 20, 2014 | 04:50 PM
chevygrl79's Avatar
chevygrl79
Well, we got it. The passenger side plug is a few inches lower than the drivers side, had to put the wipers in the upright position and used a short rod to pry on the lever. Thanks!
Old May 20, 2014 | 06:03 PM
AirborneSilva
That's great new
Old May 21, 2014 | 05:47 AM
JagNorb's Avatar
JagNorb
I hope you used WD-40 on the release cable so this won't happen again!
Old May 21, 2014 | 10:49 AM
GreenDream's Avatar
GreenDream
After once having the hood latch cable break, I always connect a short cable to each side and hide it in the cowl on all my vettes.
Old May 21, 2014 | 10:50 AM
AirborneSilva
That's a good idea, I'm going to have to do a little investigating on that
Old May 21, 2014 | 11:48 AM
JagNorb's Avatar
JagNorb
Fantastic Idea!! I shall do that today! !
To Hood latch wont release
