brake noise
Old May 21, 2014 | 09:55 PM
silvvette's Avatar
silvvette
Default brake noise
On my 80. I bought and replaced the front and rear brake rotors, hoses, pads, and calibers. Bought all from lonestar. Now only the front (when hot) make a strange noise.
Had time today to lift the front wheels off the ground and the wheels (still bolted to on) do not spin freely.
Would it be the bad pads or, rotors that lonestar sold me? (The rotors are China specials - sure wish I was told when I bought them...)
Old May 22, 2014 | 09:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by BluePastU
...Had time today to lift the front wheels off the ground and the wheels (still bolted to on) do not spin freely...
They're not supposed to. The brake pads are in contact with the rotors at all times. You should be able to turn the wheels, but they should not spin effortlessly.
...Would it be the bad pads or, rotors...
What type of noise are you hearing?
Old May 22, 2014 | 07:10 PM
silvvette's Avatar
silvvette
Thanks mike for the feedback
The noise is hard to describe the noise. It's not a squeak as must as 2 cast iron pots rubbing together.
Old May 22, 2014 | 10:26 PM
MakoJoe's Avatar
MakoJoe
Have to ask did you use any type of anti seize compound on the pins holding the calipers in place when you reinstalled the calipers on the rotors. If you did not use an Anti Seize Compound on the Pins I suggest you remove them and use a Copper Anti Seize Compound on them and remove any rust scaling you see with a fine sand paper then coat them.
If you are hearing vibration style noises from the brakes then something is hanging up and you also stated the rotors do not spin free when you spin them. This can be also caused by the nut that holds the rotor on being too tight. When tightening down the rotors what I like to do on a new set of bearings on the front is crank them down once than back them off between 1/16 to a 1/8 turn until they spin free before reinstalling the brake calipers. Then feel for any slop in the bearings. If there is slop then tighten them a little more. Always make sure your bearings are new and well greased. I like the Red Grease over the Black Grease these days. The reason I like the red is it does not dry out over the years like the black grease does and it also tends to not break down at a higher temp.
If you have brake noise it is a number of things the pistons on those older brake calipers are worn and sticking then not retracting after you release the brakes. Did you install new brake calipers or attempt to rebuild the old ones? If not you may need a set of remanufactured calipers because the old ones are worn out and sticking. If it is a pin sticking I like to use the Copper Anti Seize compound it is high heat and will not dry out like the silver color does. For normal bolts with out heat I use silver anti seize compound but in high heat areas of the car and bolts always use the Copper Anti Seize compound.
While this is a video for a late model corvette same thing applys to older model corvettes. Could just be a pin sticking.
To brake noise
