When recently I bought my 1977 L82, the dipstick appeared to have been cut off at the bottom. I didn't think much about it, but now I've started to do some investigations. A matching dipstick from Eckler's (2nd Design, 20'' to Full Mark) appears to be too long. My dipstick is actually cut off at the last L of "FULL" (perhaps stupidly, I thought this stood for low, ha).
I've searched on the internet and my manuals for info on dipstick length, but I haven't been able to find anything. Can anyone tell me the proper measurements to the proper "FULL" and "ADD 1 QT" marks?
Thanks AdamMeh. I actually already ordered that exact part. However, the new part shows that my oil is way over filled (recently changed oil and filter with 5 quarts). Maybe you are right, and the oil pan was switched out? Any idea on how to figure that out?
Also, still curious if anyone knows whether there were two different lengths of dipsticks for the 1977s...
I recently changed the oil on my 77 and same as yours it showed over full. Then it dawned on me that the replacement filter was a lot smaller than the one I removed. I bought a K&N filter and removed the small filter. I lost a little oil, but not really very much and it showed full on the dipstick. Guess I'll be buying a PF-25 next time I change it.
As to different lengths of dipsticks, I'm not sure.
How much past the full mark is it showing? The add mark is typically 1 quart below full. If you compare that distance from the full mark, it should give you an idea of how much over it is.
There is only 1 dipstick used for the '77. The part you ordered covers late '76 through '79 (all models).
Where is the drain plug on your oil pan? On the side - or at the rear of the pan? The stock oil pan would be at the rear and it holds 4 qts. The standard filter holds 1 quart, so if you change oil and filter, it will take 5 quarts total.
Adam, I think your idea is correct - the oil pan drain plug is on the driver's side of the pan. It looks super old, but I guess it was changed out at some time. I guess that is why the previous owner changed the length of the dipstick... Any ideas on how to figure out the proper amount of oil for this kind of pan?
Hmmm... That appears to be the same pan I have on our '77 (not the original to the car). As far as I know, all small block Chevy passenger car pans are 4 qt. capacity. I am running a chrome replacement dipstick that reads right at the full mark with a 5 qt. oil change including filter change.
Is it possible that your issue is coming from the dip stick tube? Maybe it's been modified somehow?
Maybe someone else here knows of a SBC pan that holds less? I'm not aware of any.
Yep, this is pretty strange. The dipstick tube measures approximately 9'' from the pan to the top of the tube. It is loose, so potentially it was changed out at some point (although it certainly doesn't look new).
I can't believe that the dipstick just broke by itself at the full mark, so I've got to believe that someone modified it for a reason at some point...
The green button on the curved part of the stick is the same as mine. Pan holds approx. four qts. and the size of the filter determines the total amount. Mine shows slightly high with five qts.. mike...
