Clutch starter interlock question
Old May 26, 2014 | 08:49 PM
EC74's Avatar
EC74
Default Clutch starter interlock question
I have a 74 4-speed that will start with clutch up or down. Obviously some previous owner bypassed this switch. Is there supposed to be a lockout if the trans in not in neutral also? Because it also starts any gear, with clutch down, for my own safety!
So is there a shifter lockout and a clutch lockout for starting, or just clutch/ Thanks
Old May 26, 2014 | 09:12 PM
Hammerhead Fred's Avatar
Hammerhead Fred
The starter should run/engage in any gear position provided the clutch is depressed.
Old May 26, 2014 | 09:13 PM
jnb5101's Avatar
jnb5101
On manual trans cars, clutch only. On automatics, neutral or park only.
Old May 26, 2014 | 09:55 PM
Peterbuilt's Avatar
Peterbuilt
Your car should only start (in neutral or any gear) with the clutch down.
You might want to check the switch first.
Old May 27, 2014 | 10:21 AM
Hpozzuoli's Avatar
Hpozzuoli
There is such a thing as an interlock (typically a rocker switch) that can be pressed/held and you can start a manual without touching the clutch. Nissan actually made some of their king can pick ups back in the 80's with these switches standard.
I have never seen them in a corvette and they really don't serve any useful purpose. I would be curious how this is being accomplished without having to throw a switch.
Old May 27, 2014 | 10:34 AM
EC74's Avatar
EC74
So does power go from the clutch switch to the starter solenoid, or is there something (relay) in line before the solenoid?
Old May 27, 2014 | 03:27 PM
Peterbuilt's Avatar
Peterbuilt
Default Trick question on a 74 Stingray!
Hi again,
For most Corvettes 12 volts positive is at the key switch but with the key "OFF" the switch is open and the power stops there.
When you turn the switch to "START" 12 volts goes to the clutch switch and cannot go and further until you step on the clutch.
After you step on the clutch the power goes to the starter.
On 1974 and some early 1975's there is a "Seat Belt / Starter Interlock".
The idea was that each passenger had to buckle up before the car would start.
It's a complicated system and many owners have bypassed that relay. There are several pages about that system in the 74 service manual starting on p 12-62.
Lets keep it simple, do you have to buckle up before your car normally would start?
Old May 27, 2014 | 04:21 PM
F22's Avatar
F22
And that switch for the clutch... It is deep inside and nearly at the top of the dash. It is almost impossible to access from underneath. I recently adjusted mine, when the dash was out, because I used to have the mash the pedal into the carpet to get it to start, but now, I just have to get close. It just comes up short of touching the carpet by a 1/4" to 1/2".
Old May 27, 2014 | 06:04 PM
EC74's Avatar
EC74
Default clutch neutral switch
Thanks for the great diagrams, the previous owner diabled a lot of things, the car will start without the seatbelts buckled, and without the clutch being down. It starts in neutral with the clutch engaged, (UP). Have never had a problem, until last night, would not turn the starter when key was turned to 'start'.
A friend was able to 'jump' the starter solenoid, and it started right up.
When I got it home, it of course started right up, several times, like nothing had happened. Guess I need to trace out the 'modifications' and find a loose connection. It was parked on an uphill, which makes me think it is a wire or some connection just moving enough to cause it to disengage, where on the level it it fine. Previous owner.....
Old May 27, 2014 | 06:40 PM
Peterbuilt's Avatar
Peterbuilt
Classic "NO" start can be from poor battery connections, so fix that first.
So you don't short anything out:
Remove and clean the negative battery cable on the battery and on the other end which is under the car below the drivers seat. Leave that cable disconnected and clean the positive at the battery and the other end at the big terminal on the starter solenoid.
REconnect the negative and try to start your car.
Good that your car starts without having to buckle up as that's another can of worms!
There is another negative cable from the starter to the block at the motor mount.
Old May 27, 2014 | 06:56 PM
Hammerhead Fred
...and just in case:
Seatbelt Interlock
Old May 27, 2014 | 08:05 PM
LS4 PILOT's Avatar
LS4 PILOT
That clutch interlock switch is in an awful place to get to.....whew...I mean you need to be able to bend like a 16 year old cheerleader to reach it.
I don't blame someone for bypassing it .....it's a 60 sec, job to bypass it and damn near impossible to get too......at my advanced age.
Seems to me it was a pair of big purple wires .....so look for a wire nut , tape etc...and purple wires under the driver side above fuse box,....I think I remember ...it was pain the BACK to reach.
Old May 27, 2014 | 08:27 PM
EC74's Avatar
EC74
Hi, battery is not the problem, it is 1 year old this month. Car has started maybe 10 times perfectly since that one time. Going to park it on a hill again and see if I can get it to fail again. I did notice when I was trying that one time that it did not start, the "brake" light in the speedo would dim just like it does when you hit the starter, so I know juice was getting somewhere, just not to the solenoid. Got a bit of hunting around to do I guess. usually a black tape job coming loose, that is why I think it had something to do with the car being tilted. All my friend did was jump the hot battery lead on the starter to the ignition wire on the solenoid and it started fine, all I was missing was the current to the solenoid. thanks for all the suggestions.
Old May 27, 2014 | 09:48 PM
Peterbuilt's Avatar
Peterbuilt
You say the battery and cables are good, OK, have you looked at the clutch switch yet?
Old May 27, 2014 | 09:55 PM
Peterbuilt's Avatar
Peterbuilt
Seatbelt Interlock
That is a very informative article, thanks for posting.
The jumper on the bottom of his page 1 is easy to do and you will not ruin a rare and hard to find relay.
Old May 27, 2014 | 11:15 PM
Texas70's Avatar
Texas70
Could it be the starter solenoid. Maybe the piston that engages the bendix was stuck and the "extra" boost from the jump freed it up. You said you thought the power was going somewhere.
One thing for sure, it will end up leaving you at the most in convenient time. Hope you find the cause first.
To Clutch starter interlock question
