Driving too much? Waterpump Kaboom!
Old May 27, 2014 | 03:45 PM
theblackvette's Avatar
theblackvette
Default Driving too much? Waterpump Kaboom!
Well, I almost had a major disaster.....
Driving this morning for a scheduled maintenance visit. As I pulled in the parking lot i heard some clanking under the hood.
I stopped the motor and went inside and we took a look. The water pump was in the process of falling apart. I was just on the highway and this could have ended much worse.
The current water pump is not correct for the car. But I have the correct one at the house. I rented a car, drove home, and shipped out the goods. At the same time, I will have the alternator put in, along with the door locks fixed, and the routine maintenance i went in for.
How in the heck does a water pump crap out to the point it is dancing on the motor?
Old May 27, 2014 | 04:04 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Hey Marc,
Dancing on the motor?? You should have two bolts on each flange, that water pump should be very secure and should not move even if the internals have given out. Any more details?
Old May 27, 2014 | 04:07 PM
early shark's Avatar
early shark
On one of my '71's, an LS-5 coupe, the water pump exploded into three separate pieces. I heard a loud bang, the hood popped up and a clanking noise. I was doing about 130 mph when this happened, shut the engine off and coasted to a stop. The three hoses still had portions of the water pump attached, the 7 blade fan and clutch went into the radiator, with one of the blades coming off and slicing thru the hood. Upon close inspection I could see rust near the fractured water pump pieces.
Old May 27, 2014 | 04:11 PM
theblackvette
Originally Posted by LeMans Pete
Hey Marc,
It sure sounds like it was dancing. Perhaps the pulley on the water pump. I was also shown the belts needed replacement. But, it was shot and glad it didn't blow up on me. The mechanic took a stethoscope to listen closely to see exactly where the noise was coming from. It was from the waterpump.
I do believe and it was pretty obvious much more driving would have had a VERY bad result. Just sharing my experience with my ride.
Old May 27, 2014 | 04:13 PM
theblackvette
Oh gosh! I think mine was going to do the same! What a horrible experience.
Thank goodness this didn't happen to my car. And note to MYself...don't drive 130 mph! Nice to know that they will go that fast though.
Old May 27, 2014 | 04:39 PM
qwank's Avatar
qwank
the bearings probably wiped out so the impeller was "dancing" around
Old May 27, 2014 | 04:53 PM
theblackvette
I will certainly check the final reason why the pump went cuckoo....
All I was doing was going in for a regular check and maintenance and ended up leaving the car. I have done a LOT of driving and it shows. It needs a real good cleaning underneath. Getting all the crud and grease out of there. You can see a lot when a car is on the lift, that is for certain!
Old May 28, 2014 | 04:01 PM
dochorsepower's Avatar
dochorsepower
If you want to feel better about your situation, go price what it costs to replace a water pump in a C-6 Vette.
Old May 28, 2014 | 05:00 PM
theblackvette
Doesn't look all that bad for the PART!!!!!!!
Maybe the labor costs?
Wow....kinda looks like my waterpump that I am putting in my car. Maybe with a few upgrades but basically same configuration. Interesting!
http://www.ebay.com/itm/2009-2013-Corvette-C6-water-pump-new-take-off-/291134578168?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2010%7CModel%3ACorvette&hash=item43c8f91df8&vxp=mtr
Old May 28, 2014 | 05:13 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Well B.V.............if it has to fail.....it certainly picked a good spot!
And you are getting other things repaired.....WIN/WIN!
Old May 28, 2014 | 06:44 PM
theblackvette
Yes this visit has pretty much began the installation phase of my "project" for ncrs. I have a few more items "big stuff" that are available that I plan on purchasing. There are other minor things that I may not get to. But it looks like I entered the next phase.
To Driving too much? Waterpump Kaboom!
