The diagram I posted was for a 69, another member had posted it.
I see only two grooves being used on the crank pulley for all applications. Could be you have the wrong crank pulley. I can look at mine when I get home, think it's a two groove. The crank pulley should have a part number stamped on the flat surface, front side. Maybe see if it matches the AIM?
Are you shooting for originality? If not, other members have come up with some creative configurations.
It's kind of hard for me to tell... But the water pump should be three groove, the alternator pulley should be single grooved, but a thicker pulley to allow the belt to match up with power steering pump. The power steering pump should be a two groove pulley and be cast iron.
Boy that back idler belt is a fun one to install too... it looks like your upper and lower pulleys may be correct, you can tell if the p/s pump pulley is correct by seeing if it's cast iron and make sure it lines up with the first and second groove of the water pump and crank pulleys.. .
The part numbers are on the picture
Willcox
the other two pulleys look fine.. but the lower should be cast as well.. Hard to tell.. but if it is, it should have a p/n on it 3863108. From my standpoint... before you buy a bunch of other pulley that are expensive... I would get the alternator pulley, install it on the alternator and see if it lines up with the second groove on the power steering pump..... If it does then the rest should work for you.
FWIW: I have a two groove crank pulley, part number 3921923 and a 3 groove water pump pulley, part number 3889372, which agree with the AIM for an LS5. The alternator pulley part number is 3846180.
This combination should work on a 427 as well.
Yes indeed, I stand corrected.. I forgot they split they year in 69. 3963108 stopped at aprox. s/n 24000. All big blocks after that went to the 3921923.
On my 72, 2 groove crank, 3 on the water pump, 2 groove P/S (cast)
The alt pulley is pretty much twice the thickness of a normal one with the groove out at the front which goes perfectly with the front p/s groove
This pic is on the cs144 I'm switching to but it's the pulley from the old alt and the mounting dims front - back are the same one the two styles,
In
A71Vette has his mounted with a set of spacers (seen where the alt mounts to the two different brackets) that I don't believe are stock but allow a single groove pulley to work and provide some much needed room at the valve cover
