Engine Starter harness.
Old May 31, 2014 | 11:58 PM
drakur197's Avatar
drakur197
7th Gear
Default Engine Starter harness.
Hello, just joined as I just bought a corvette.
Now, the previous owners replaced the original motor and some of the wiring is messed up, I hot wired it to get it in the garage. SO what the issue is, I am missing the engine harness that goes to the starter. However the Blue wire on the harness connector is also cut. So I am wondering where that one goes. I also think the removed the A/C. It has the A/C bits but no compressor. SO second question is that there is a big red wire, currently on the fuse in the pic, and from what I can see from the schematic is that it goes to the A/C hi blow relay. If someone could confirm this with a picture, I would appreciate it. Last of all on the starter harness there is two red wires, that I have determined to go to the main power feed wire, purple goes to the solenoid, does the black wire go to the power feed or through the solenoid as well. Schematic shows to the power lug, but seems odd ??
